Valve adjustment
Old Dec 17, 2005 | 05:10 PM
Capp's Avatar
Valve adjustment
I'm wanting to adjust the valves on my 91 D250. The repair manual that I have says you need a Berring tool to rotate the engine. Does anyone know another way, and where I could get the tool if I need it.
Old Dec 17, 2005 | 05:18 PM
ctd89-99's Avatar
Valve adj.
You can use the alternator pulley nut 7/8" to turn the engine. Thanks Steve B.
Old Dec 17, 2005 | 09:19 PM
jrs_dodge_diesel's Avatar
Yep, 7/8 in socket on the alternator pulley. This method rotates the engine backwards but its works good, i have done it.
Capp, check out my gallery. I have some greeat pictures in there from when I did my valves. I put pretty detailed descriptions in each picture.
Old Dec 17, 2005 | 10:49 PM
ratsun's Avatar
I couldnt use the alt pully(belt just slipped) so I just used one of the damper bolts and a long handle rachet.
Old Dec 18, 2005 | 04:03 AM
It will slip if you turn the pulley the wrong way. You have to turn the pulley counter-clockwise (looking at the alternator from the front of the truck).
Fishbait
Nov 23, 2009 11:21 AM
ConnerCop
May 5, 2009 07:48 AM
dhughe2
13
Dec 6, 2006 07:40 AM
bulthisl
Mar 22, 2003 07:01 AM
blackboat
Nov 8, 2002 06:32 PM
