transmission mount
Old Nov 5, 2007 | 12:22 PM
DMAN99's Avatar
transmission mount
the 95 in sig broke the tranny mount the first time I pulled it and before that I hadn't drove it very much so I thought I would try a new mount but was a waste of time b/c didnt get more than 40 miles out of the new one. Anyone know where I can get a heavy duty one or any ideas what I can do to make the stock one better or how to make one. Thanks
Old Nov 5, 2007 | 02:03 PM
gmctd's Avatar
DCX version is stronger than the aftermarket brands, and the NV5600 support is stronger than the NV4500 - might give that one a try
Old Nov 5, 2007 | 02:55 PM
DMAN99's Avatar
the second one I put on was a 5600. Where would I get a DCX version?
Old Nov 5, 2007 | 03:40 PM
lgp9999's Avatar
Really, you're having a problem with constantly breaking tranny mounts? The only time I have broken one is when I had a broken motor mount... might wanna check into that.
Old Nov 5, 2007 | 05:34 PM
DMAN99's Avatar
motor mounts don't seem to be broke at least the steel around the rubber but the rubber seems uneven and kinda bad
Old Nov 7, 2007 | 08:27 PM
DMAN99's Avatar
upon further review the engine mount had a crack in the steel part of the mount so I took it out to fix it and found that the rubber was torn badly and the crack was bad so I fixed the crack and built the rubber part of the mount out of an old leaf spring end. Wont break again!
Old Nov 7, 2007 | 08:48 PM
dodgeman01's Avatar
I have replaced motor and tranny mounts 3 times lol. can I just weld the dang thing up
is there a better motor mount out there?
DM01
Old Nov 7, 2007 | 09:09 PM
DMAN99's Avatar
i didn't weld the spring end in place on the mount for the fact that the mount is cast and I was afraid to weaken it. But some would say it wouldn't hurt it but I wouldn't. Just find a spring end that is 3" in dia on the out side and get a pice of rubber ie a fernco fitting and drive it inside the rubber and then size the inner hole down to disired size of bolt. I went with a 1/2" grade eight bolt.
J10495T
Sep 21, 2011 04:07 PM
Loopi
Nov 22, 2008 10:15 AM
chw
Dec 25, 2006 04:30 PM
Jambbii
Jul 4, 2005 04:23 PM
12valve@heart
Aug 11, 2004 03:43 PM
