Timing tools
I got my bluepoint timing kit (one snap on sells) month or so ago haven't gotten chance to use it but its nice was like $221 i think already got the barring tool it doesn't even feel like ur doing anything its that easy turning the motor over.
No, the barring tool is seperate.
Snap-On #s:
SP500 Set, Diesel Timing Gauge
M3584 Compression adapter
YA9565A Engine turning tool
SP144 injection pump wrench
All the shops I talked too only set timing to factory specs, not what I want and easy enough for me to do that!
Snap-On #s:
Compression adapter is for cylinder compression tests. I already have a diesel compression gauge and adapter for 6.2/6.5 engines and figured I'd get the one for the CTD also.
Yes you can do the timing without the wrench. I swapped a p-pump without it but figured I might as well get it. It should make getting at the backside nuts easier, I hope. It was a PITA on my motorhome.
GR40RCapri
Jun 25, 2006 12:53 AM
