Boost drop off
Old Sep 30, 2006 | 11:18 PM
Mslaughter's Avatar
Boost drop off
Today I was driving and floored it to pass a car and noticed the gauge spiked to 25psi then after a couple seconds dropped to 21-20psi and stayed there? The only thing I could think of was the pre spool fuel load hitting causing boost to spike then go down? Or maybe my govenor arm needs adjusted?
Old Sep 30, 2006 | 11:30 PM
oldsmokey97's Avatar
try changing the fuel filter!!! Mine did the same thing.
Does it have sorta a popping/missing sound?
Old Oct 1, 2006 | 11:17 AM
Mslaughter's Avatar
No the engine runs smooth, The filter was changed less than 3k miles ago.
Old Oct 1, 2006 | 11:20 AM
Clayten's Avatar
DTR's Toad Wrangler
I would say you are on the right track with the governer arm. Sounds like it might be just a bit high. Move it down just below the tip of the J hook. Should be able to bring the boost up to about 32- 34 psi
Ron R
Sep 16, 2008 11:09 AM
darrenG
Jun 28, 2005 07:43 AM
JeffJ
Sep 30, 2004 02:22 PM
Tfeore
Mar 29, 2004 07:25 PM
coastal_diesel
Mar 19, 2004 12:56 PM
