Timing Pin one more time
Old Aug 11, 2018 | 09:09 PM
rebar's Avatar
I fought locating tdc with the cam timing pin on my last 12v. Why did cummins put such a big o-ring on it, its so hard to move! I finally pulled the sob right out because I pulled so hard just to move it, it popped the retaining ring off, but then I could see the cam hole!
Now I have another 12v, but its 4x4 and even tighter reaching up there with the axle/linkage in the way. No way barring over while at the same time pulling/pushing that sob pin in and out wondering if it landed or not. Arrrrr!
Whats the solution here? I don't have a helper.
Is the drop valve method the best and then bolt a pointer to the speed sensor, file a groove in the balancer and forget the timing pin forever?
Thanks!
Old Aug 12, 2018 | 07:16 AM
nonrev's Avatar
Super Moderator
10 Year Member
They are definitely a pain, what I do is get a helper, spray the pin with your choice of lube, move it back and forth a few times to get the o-ring lubed and the crud loosened up, then pull the #1 valve cover off get the # intake to just almost closed position then have the helper use the barring tool to slowly turn it over while you push the pin in (I've had to use a prybar on the end of the pin to get it to go into the hole before)then file a mark on your balancer.
With that being said there is also the possibility that the PO forgot to pull the pin back out and snapped it off when they turned it over to do the second set of valves. I will try and get a picture today showing how far in the pin will go without being lined up so you will know if yours is not broken off.
Old Aug 12, 2018 | 01:28 PM
rebar's Avatar
Thanks Nonrev..
From my previous 12v experience, the small amount (guessing 1/8") of pin movement this new 12v has means the pin still has the locating tit. I doubt anyone has ever used it.
The problem is that the pin so difficult to move. I was thinking about making a tool that would hold the pin loosely, and push and pry from a empty bolt hole close to the pan, like a seesaw. But by the time I built it, I could have completed the drop valve method.
If I do the drop valve method, is using a home made pointer accurate enough for all procedures requiring TDC? I don't like the pointer in the video because its located to far from the balancer surface
Old Aug 12, 2018 | 09:06 PM
gorms's Avatar
If I remember right, I was able to bar the motor over with the alternator (or one crank bolt) with one hand and pull the timing plug out to feel for the notch with my other hand at the same time. Reaching from top of the engine bay.
I also pulled the injector timing plug out and watched for the timing indicator to come into view, to get it close.
Old Aug 13, 2018 | 05:47 PM
texasprd's Avatar
I use the barring tool, and am able to bar the engine over with a 1/2 ratchet. Not fun while trying to push the timing pin in, but do-able. I'd be very wary of filing a notch in the damper - the ESS reads the damper notches to determine RPM and other functions. If you put in extra notch in the damper, you may have unexpected side effects. Maybe scribe a line or make a punch mark, if you can do it in an area not covered by the ESS?
Old Aug 16, 2018 | 08:34 AM
rebar's Avatar
Thanks texasprd, but I have no idea how you got your arm up to the pin.. 2wd? I can barely reach it, let alone grab it and overcome the oring. I finally pulled the retaining ring out and pulled the entire timing pin the hell out like another 12 valve I owned. Then I put tension on the, tensioner.. So that I could turn the engine clockwise just to see if I could, stuck my finger in the pin hole and felt for the cam hole as I turned it over. When it got close I put the pin in without the o-ring, and turned a bit more to set it. Then I noticed someone had already paint marked the balancer to the speed senser. lol
Im slowly getting closer to that kdp.. drum roll
Old Aug 16, 2018 | 03:08 PM
texasprd's Avatar
Yes - I have a 2WD. And I like to practice contortionist exercises for the heck of it... lol Even with the 2WD, I admit it's difficult and painful to reach around and deal with that pin. When I reinstalled my IP after overhaul, I accidentally pulled the pin out like you mention. That did let me use a mirror to see when I was getting close, and pop the pin back in at the very end.
Old Aug 21, 2018 | 01:21 PM
rebar's Avatar
I removed the timing pin and o-ring and lubed it with vacuum pump grease. It moves so much easier now.. So easy, I'm not sure if I'm comfortable without the retaining ring re-installed..
G1625S
May 14, 2012 10:31 AM
mechmagcn
Oct 12, 2011 10:29 AM
DodgenIt
15
Apr 24, 2010 08:06 PM
wvopowered
Jul 7, 2008 12:20 AM
65fury
Jul 23, 2007 09:11 PM
