Ticking noise
Old May 28, 2006 | 12:42 AM
Teddy Bear's Avatar
Ticking noise
When running, my truck has a constant ticking noise. Its especially noticeable at idle. At first I thought my exhaust might be a little loose, but i checked it and it seems tight, so what do i do next? Where is it coming from?? Could it be the valves or lift pump?
Old May 28, 2006 | 06:20 AM
JD730's Avatar
My brother's did the same thing, you could really hear it back by where the bed and cab met. Crawl underneth with something you can put up to the fuel lines and your ear (screwdriver comes to mind), if you hear it tapping in the fuel lines, the most likely thing it could be is the lift pump then after that the overflow valve.
Old May 28, 2006 | 08:07 PM
wayne74447's Avatar
wow mine is doing the same thing....
Old May 28, 2006 | 08:30 PM
boostedte37's Avatar
mine too seems to be coming from the front on the engine
Old May 29, 2006 | 01:06 AM
Hemi Cat's Avatar
Lift pmps are high on the probability list. Take an old heater hose about 2 feet long and hold one end to the pump and the other end to your ear (the clean end). If it is making the noise you will hear it loud and clear. If not keep going around the eng until you locate it.
Old May 30, 2006 | 09:37 AM
Txwelder's Avatar
After a new lift pump and two new overflow valves it still ticks. I have just grown to deal with it.
Old May 30, 2006 | 01:35 PM
Teddy Bear's Avatar
Well that makes me feel good
Old May 30, 2006 | 01:51 PM
Txwelder's Avatar
Read some of my past posts on "ticking". Most of the guys that have been driving these 94 and up 12V's since 94 tend to have the same idea about it. They all tick now and then, sometimes it is worse than other times.
Old May 30, 2006 | 10:26 PM
DZLPWR's Avatar
Mine ticks too, espes. around 1500rpms, valve adj. did nothing for it, so i guess its the lift pump
Old May 30, 2006 | 11:02 PM
benny852's Avatar
Mine was ticking yesterday at about 1500 rpms and today its not ticking at all.
Old May 31, 2006 | 12:32 AM
Hemi Cat's Avatar
The only time mine had a tick was a few days before the lift pump failed. I have around 40,000 miles on the new eng without any ticking. Gotta be somethig in the check valves inside the pump. I put a carter pump on mine. maybe they have a different style check valve or seat.
Old May 31, 2006 | 01:26 AM
San Felipe Bob's Avatar
Overflow valve !
Every time mine ticks it's been the overflow valve.
I got my last one from Piers.
It's ben holding up well since I've been changing my fuel filter more often.
SFB
Keep you fuel filter changed !
1985cucv
Apr 11, 2010 10:42 AM
Mostwanted
28
Nov 3, 2005 06:18 PM
SmokinDodge12V
Aug 1, 2004 05:00 PM
RamRat
Feb 12, 2004 08:46 PM
yrusoslow2
Feb 9, 2004 12:31 AM
