Ticking noise
Old Jul 27, 2004 | 09:12 PM
SmokinDodge12V's Avatar
Ticking noise
Ive got this ticking noise not valve chatter or anything like that but it is very noticalbe its coming from the drivers side of the engine it just started one day and seems to have gotten a little worse and im loosing about 3-4 lbs of boost I dont know if the ticking has anything to do with that or not but it still starts fine and seems to run fine. Any thoughts, Thanks
Old Jul 27, 2004 | 09:28 PM
infidel's Avatar
Overflow valve ticks when it starts going bad.
Old Jul 27, 2004 | 09:31 PM
Is the overflow valve located at the top corner of the pump towards the front of the motor. Thanks
Old Jul 27, 2004 | 10:29 PM
bmoeller's Avatar
I had to replace my lift pump a couple of months ago.It was making a ticking noise. Found that the spring inside was shot.
Old Jul 28, 2004 | 08:06 AM
winner172's Avatar
I replaced the overflow valve and lift pump trying to get rid of the tick. just learned to live with it.
Old Jul 31, 2004 | 10:57 PM
Are there any other symptoms of a bad overflow valve going bad, its cutting out at heavy throtle but no white smoke. Thanks
Old Aug 1, 2004 | 05:14 AM
infidel's Avatar
low RPM miss/instability
white smoke
hard starting
engine dies at idle
low power
Old Aug 1, 2004 | 06:46 AM
Smokee's Avatar
Sure sounds like an overflow
Old Aug 1, 2004 | 05:00 PM
bmoeller's Avatar
http://www.dodgeram.org/tech/dsl/tro...p.htm#Overflow
1985cucv
Apr 11, 2010 10:42 AM
Mostwanted
28
Nov 3, 2005 06:18 PM
Bones
Oct 15, 2004 09:26 AM
RamRat
Feb 12, 2004 08:46 PM
yrusoslow2
Feb 9, 2004 12:31 AM
