Tapping Sound
Old May 27, 2006 | 09:15 PM
carter5875's Avatar
Question Tapping Sound
This just started a few days ago. When I first start the engine it runs smooth.
After it warms up it starts to tap. I bought the truck used and I am not sure what regular maintenance was done. Could this be the lift pump, Valves?
Does anyone have any suggestions????
Old May 27, 2006 | 10:41 PM
88bird's Avatar
fill in your signature so we can know what year and model and mods you have to the truck..... then we can help you more....
Old May 28, 2006 | 10:12 AM
carter5875's Avatar
tapping sound
Sorry,
Basically everything is stock. 1998 12 valve dodge diesel. Straight exhaust. THats it.
Old May 28, 2006 | 08:33 PM
marine4life's Avatar
that tapping noise can be due to a bad overflow valve. Mine tapped until i replaced it, i've also seen a bad lift pump as well.
Old May 29, 2006 | 01:01 AM
Hemi Cat's Avatar
lift pumps will sometimes make a ticking noise while they are starting to fail. It is just a plunger pump with 3 one way check valves that beat themselves apart (non replaceable). Use a hose about 1/2 in or so (heater hose is fine) about 2 feet long. Hold one end to the pump and listen in the other end (the clean end). You will hear the noise loud and clear if it is there. If not, keep going around the eng until you locate it.
Old May 31, 2006 | 01:30 AM
San Felipe Bob's Avatar
Thumbs up I vote for the overflow valve
They are easy to test if you have a fuel pressure gauge.
SFB
samiam4
Dec 19, 2012 12:08 PM
esde
May 5, 2011 11:40 AM
Lurch519
Apr 24, 2010 10:31 AM
atown
Sep 16, 2009 11:29 AM
fl dodge
May 27, 2009 11:46 PM
