Tansmission dipstick leak
Old Jul 25, 2011 | 07:20 PM
taneum's Avatar
I think I found my elusive transmission leak after changing the pan gasket with the spendy one from the dealer. I picked up the o'ring today. Anything I need to know when replacing this? How much fluid will I lose when I pull the dipstick tube? Should I do it on a hill?
Old Jul 25, 2011 | 09:43 PM
oldblues's Avatar
hi
do it on a hill ,clean the area around tube and trany before puling it . have a plastic plug ready to stick in the hole till you change the o ring
should only loose a small amount if you re quick
Old Jul 25, 2011 | 10:00 PM
taneum's Avatar
Thanks for the reply. Does the o'ring go on the dipstick, or in the transmission when you install it?
Old Jul 26, 2011 | 11:08 PM
oldblues's Avatar
hi
it goes in a indentation on the dipstick tube .
you will see this when you remove the dipstick tube as the old o ring should be on the tube app 1/2 in from the end of tube .
dont use any sealer just a little trany fluid for lube on the new o ring so it slides in easiy .
Old Aug 4, 2011 | 11:32 AM
taneum's Avatar
Well I stopped the leak with the new o'ring. I went to put in the rubber plug to stop the flow of tranny fluid and it was too small and fell in the tranny pan (so I had to pull the pan too). After changing the pan gasket two times it was the Dipstick o'ring. If you have fluid on the bottom of you pan make sure you check the o'ring before you change your gasket.
Matthew999
Feb 17, 2010 04:24 PM
1985cucv
15
Apr 17, 2009 09:06 AM
Teach
Apr 11, 2007 06:28 PM
Twogun
Feb 24, 2006 10:28 AM
1Ton00
21
Nov 13, 2003 12:40 AM
