pushrods and cowl hole won't align
Old Sep 13, 2012 | 04:13 PM
hounddogks76's Avatar
I found the holes above the pushrods in the cowl, but when you try to pull the rocker headbolt or the pushrods up, the hole in the cowl is about 1/2 inch to far to the drivers side. This truck had a fender bender before i got it, i wonder if the body is tweaked enough to cause this. Any one else had this problem?
Old Sep 13, 2012 | 06:29 PM
BigIron70's Avatar
Cummins Guru
Motor mounts broken, or cab wasn't bolted to frame correctly.
Old Sep 13, 2012 | 07:45 PM
I don't know which, but i finally got the buggers out with help of a friend and a lot of head twisting.
04ctd
Jun 7, 2009 08:27 AM
bigyoda
Aug 19, 2007 11:03 AM
Mr. Jimmy
Jun 15, 2006 10:48 PM
GO 4LO
Nov 1, 2005 02:59 PM
jrs_dodge_diesel
Jan 12, 2005 12:13 PM
