p7100 injection pump delivery valves ???
heeelllp needed !
retimed my 98 12v and when i removed the delivery valve for no 1 there was
no copper washer under the delivery valve barrrel ?
sooooo i removed no 6 and no 3 delivery valves to see if they had the washers .
no washers here eather ?
all instructions i have read about timing the engine say to replace these washers ?
do all pumps have them or were they not on the 98 ???
98 2174 cpl if it matters ?
now also i noticed the barrel < outer part of delivery valve has a machined step on one end ,
some had the step installed on top some had it on bottom ??
witch way is correct ?
thank you !
thank you !
tommurray
02-23-2014 10:38 AM
pwrtripls1
09-29-2011 09:34 PM
stock600
05-21-2008 06:48 PM
