p7100 injection pump delivery valves ???
heeelllp needed !
retimed my 98 12v and when i removed the delivery valve for no 1 there was no copper washer under the delivery valve barrrel ? sooooo i removed no 6 and no 3 delivery valves to see if they had the washers . no washers here eather ? all instructions i have read about timing the engine say to replace these washers ? do all pumps have them or were they not on the 98 ??? 98 2174 cpl if it matters ? now also i noticed the barrel < outer part of delivery valve has a machined step on one end , some had the step installed on top some had it on bottom ?? witch way is correct ? thank you ![duhhh][duhhh] |
