VE Pump Delivery Valves Question Help
I put an I/C pump on a non I/C engine. Can't get it to start. Started once on ether, but tried to runaway. Anyway some people said it wont never run until I put the correct delivery valves in the back of the pump. Is this true? I didn't have any trouble hooking up the injection lines. Thanks
There is not a huge difference in injectors between a Non-IC and IC. Yes the Non-IC injectors will flow more fuel compared to stock IC injectors, but nothing that would require different delivery valves. Plus to my knowledge the injection pulse generated to pop the injectors is created inside the IP, not in the delivery valves.
Was this IC pump "know" to be working before? Did you re-seal it before installing it? Sounds like an internal IP issue. Maybe FSS stuck closed?
pwrtripls1
09-29-2011 09:34 PM
stock600
05-21-2008 06:48 PM
yrusoslow2
08-13-2003 11:26 PM
