new truck, white smoke
Old Apr 15, 2007 | 10:01 PM
smokin'joe0778's Avatar
Hello again, I bought a new truck on friday, 95 reg cab CTD 5 spd 66,000 original miles. the truck starts and runs great, but...in the morning when I leave the house it just shoots a steady streak of white/blue smoke at all RPM's but then clears in about 4-5 miles, and only in the morning. Got any ideas??
Old Apr 15, 2007 | 11:27 PM
labreck's Avatar
its just cold. i think. you might have it checked out. thats low miles for a 13 year old pickup, it sat for some time i can olny asume. could be gumed up injecters. try some injecter cleaner.
Old Apr 15, 2007 | 11:41 PM
jrs_dodge_diesel's Avatar
White smoke on a diesel engine usually indicates that the combustion temeratures aren't hot enough to completely burn all of the diesel fuel. Basically, the engine is too cold. This can be prevented by utilizing the block heater.
Old Apr 16, 2007 | 04:42 PM
phox_mulder's Avatar
White smoke is also indicative of slipped timing.
Not being familiar with the undervalved, doesn't a 12 valve have something that changes the timing on first start up, then as the engine warms up it changes it back to normal timing?
Perhaps this "something" is not working, thus the white smoke till it's warmed up?
phox
Old Apr 16, 2007 | 04:43 PM
Not a 2nd gen, the P7100 is a "stupid" pump. I agree that it sounds like the timing has slipped.
Old Apr 16, 2007 | 04:56 PM
berner's Avatar
Along with timing, check the fuel pressure. It could be a plugged fuel filter or pre-heater screen, weak pump or a worn out overflow valve. You might want to run a bottle of good injector cleaner through it too.
Old Apr 16, 2007 | 05:00 PM
G1625S's Avatar
oh that's funny right there
Old Apr 16, 2007 | 05:11 PM
Lil Dog's Avatar
phox
You are thinking of the KSB solenoid on the older VE pumps (89-93).. Nice of you to consider us under-valved in your travels.
Sounds like timing to me as well. The fuel system is a good start, conditioner, filters etc then a possible look at the Overflow valve. A failing overflow will make the timing late and cause the same symptoms without the "slipped" timing off the gear.
Old Apr 16, 2007 | 06:21 PM
thanks for all the help, I check the fuel heater and its not working got a new heater, wiring harness and pre-filter kit coming, as far as the overflow valve I forgot to mention that I put a new one in [had it layin on the shelf] and still no good. when I get the fuel heater back together I'll be able to find the true furl pressure and then if that dosent help I'll tear into it and re-time the pump. Thanks again!!
Old Apr 20, 2007 | 05:32 AM
diesel don's Avatar
White smoke
And last but least don't forget to check fuel supply and returns lines for cracks you will get white smoke from air in the fuel it cause retarded timing.
recone5
Nov 5, 2008 10:26 AM
RJOS
16
Sep 3, 2007 09:19 PM
BuildingBoost
Mar 25, 2007 07:46 PM
BlackSheep5
Nov 27, 2006 07:52 PM
dhe9
Nov 14, 2003 07:31 AM
