New Overflow Valve Install
Old Apr 2, 2004 | 11:00 PM
Crimedog's Avatar
Well, Got'er ordered form Precision Diesel, 30 bucks with the oring, and 5 bucks shipping. I'm hoping I can get a little better than 14.5 now!
How does the overflow valve affect milage? Doesn't it just return un used fuel back to the tank, so wouldn't it be used eventually anyway?
Old Apr 2, 2004 | 11:50 PM
infidel's Avatar
The OF valve regulates the fuel pressure supplied to the injection pump. If the FP is too low the injection pump struggles to provide enough fuel to the injectors at the correct pressure. Power and mpgs suffer.
Old Apr 4, 2004 | 06:59 PM
Txwelder's Avatar
Isnt there just a spring you can buy instead of the whole valve? If not a spring made for that application then a like spring that would do the job?
Old Apr 4, 2004 | 07:11 PM
infidel's Avatar
I provided an OF valve spring to a guy who is great finding that sort of thing, works at Boeing. Others on TDR have tried to source one. No luck.
Sometimes the problem with the valve isn't just the spring, the ball can get a ring worn in it. Easier to just pay $30 for a new valve.
Old Apr 6, 2004 | 08:29 AM
DRM's Avatar
DRM
I might just have to replace mine and see what happens...
Old Apr 7, 2004 | 07:35 AM
1ST CUMNZ's Avatar
Anybody have a link to install the ov
Old Apr 7, 2004 | 10:11 AM
infidel's Avatar
It's so simple it's hardly worth a link. Just remove the old one and put new one in it's place. Don't lose the washers. Occasionally the notch in the manifold you see to the left of the OF valve in the picture needs to be filed or ground a little to allow the old valve to be removed. Don't bend the line to remove the valve, it will make it very difficult to line up right again. New style OF valves don't have the retainer on top that says not to remove, don't worry it's just a design change.
The object in the lower left corner is your oil fill cap.
Old Apr 7, 2004 | 07:10 PM
Crimedog's Avatar
Called up Diesel Injection and Turbo, ordered it last Thursday(they said it would ship the same day), figured it would be here by now, so I called them and they said it just shipped today Oh well, I'm sure it will be worth the wait.
Old Apr 8, 2004 | 08:53 AM
1ST CUMNZ's Avatar
Thanks for the link slash diagram
Common
Feb 29, 2008 06:00 PM
Ru rammin 2?
34
Jan 23, 2008 07:21 PM
MR HYDROSEED
Sep 6, 2007 07:30 PM
RenegadeT
Jun 13, 2007 10:30 AM
Jeremy Cusick
May 8, 2004 09:56 PM
