used overflow valve in new IP
Old Jun 12, 2007 | 09:48 PM
RenegadeT's Avatar
The factory service manual says Do not install a used overflow valve into a new or remanufactured pump.
What do I risk if I do use my old overflow valve?
Old Jun 13, 2007 | 10:30 AM
CarlJensen's Avatar
The OFV establishes the internal pressure in the IP. If the valve is bad internal pressure will be wrong. If the spring in the used OFV is good, and at exactly .5 inches, it will give the pressure required and should work just fine.
Buzz'nhalfdozen
May 27, 2009 12:19 AM
Common
Feb 29, 2008 06:00 PM
MR HYDROSEED
Sep 6, 2007 07:30 PM
Jeremy Cusick
May 8, 2004 09:56 PM
wagontrain131
23
Apr 8, 2004 08:53 AM
