multi-function hi/lo and wiper switches
Old Aug 27, 2020 | 11:25 AM
rootercycles's Avatar
All,
As I put together my dash, I keep running into electrical gremlins.
The newest ones are that I am able to pull the arm back of the combination switch to the hi beam, but it will not stay on hi. the second issue is that the wipers will not turn on. I've switched out the combo switch apparatus thinking it was this cheap part, but the same result.
All of the fuses are intact, so I'm stuck. Any ideas where to go next to diagnose this? Should I look at the relays?
Old Aug 29, 2020 | 09:05 AM
cougar's Avatar
What year truck are you talking about? Each generation poses its own mysteries. Something I found with my 01 is that LEDs really screw things up.
Old Aug 29, 2020 | 09:10 AM
Yeah, that might be helpful. It's a 1995 Dodge Ram 2500. I converted it from Auto to an NV4500. I've worked out most bugs except A/C, hi/lo, wipers, and headliner "info-center". I had to completely remove interior and dash down to just the harness. I suspect there may be fractured wires in places. I hate to take it apart again, but want to get this thing done!
Old Sep 7, 2020 | 10:20 AM
cougar's Avatar
Wiring. Fortunately 94-95s are still relatively basic technology wise. Easy to pinch something when you have it that torn apart. I hope you have the factory service manual.
mopar2ya
Mar 1, 2020 09:40 AM
Diesel_Power_2
Oct 23, 2010 10:29 AM
Big Smoky
Nov 30, 2006 05:14 PM
serious
Mar 17, 2006 04:49 PM
Paws
Jun 1, 2004 08:01 AM
