Wiper elctrical problem
Old Mar 15, 2006 | 02:27 PM
serious's Avatar
Hi all, my wipers on my truck are not working properly. Mechanically they're fine, but electrically they are not working right. The intermitant feature is well intermitant in working and when you turn the switch to the off position the wipers stop where ever they are at.
I'm thinking that it could be the switch or the control modual. Anyone ever have this problem?
Any ideas?
Thanks
Brent
Old Mar 15, 2006 | 04:20 PM
crunchybuttr's Avatar
Not the same issue, but when my wipers simply quit a couple months ago... I narrowed it down to a short; somewhere in the miles of cable in the dash . I feel like yours is probably just an "intermittant" connection... one thats worn or corroded in there. Have you checked all the wires?
Old Mar 15, 2006 | 04:46 PM
serious's Avatar
Haven't checked them yet, i thought i would post to see if this is a common problem or if i would have to start checking every wire and component.
Thanks
Brent
Old Mar 15, 2006 | 05:46 PM
Time for a new wiper motor. The park switch is dead.
Old Mar 15, 2006 | 06:07 PM
serious's Avatar
Can you replace just the park switch or do you have to replace the whole motor assembly to do this. Also are you a 110% sure of this? I'd hate to replace the motor and not have that be the problem.
Thanks for the reply.
Brent
Old Mar 15, 2006 | 06:12 PM
The park switch is part of the motor assembly and is not serviceable.
If they stop wherever you turn them off, the park switch is bad.
Old Mar 15, 2006 | 11:46 PM
Underpsi's Avatar
My wipers would sometimes randomly stop at any position and it was only due to a bad ground. I took the wiper apart before realizing about the ground and the brushes were like new!
Old Mar 15, 2006 | 11:47 PM
serious's Avatar
I was hopping to get out of this one easy...
Thanks
Brent
Old Mar 17, 2006 | 11:06 AM
Well, a wiper motor is pretty easy when you think about checking every connection in the dash... a little pricy though.
Old Mar 17, 2006 | 04:49 PM
serious's Avatar
I ment easy as in the cash part. A new motor is around a 100 bux.
Brent
2kayaks
Jan 25, 2014 06:01 PM
Devin_01
Dec 12, 2006 09:37 PM
FastSS
Apr 16, 2006 02:48 PM
Dorkweed
Feb 14, 2005 04:19 AM
