low idle at startup
Old Jan 24, 2023 | 10:16 AM
texasprd's Avatar
If adjusting on the truck, use a 1/2"-drive ratchet, suitable extensions and u-joint, and a barring tool to turn the engine and thus the pump... Check your PMs.
Old Jan 31, 2023 | 06:24 AM
Tate was referring to tightening or loosing the two special screws that apply spring pressure to the Gov springs.
The screws turns about 90* then they make a click. Adding or loosing the screw a click or two will modify the rate of the gov springs and you should be able to fine tune this problem away.
I just adjusted some new 4 K Gov springs I installed in my '97 215HP motor. I turned the screw head out a couple of clicks to lower my upper end RPM range a little bit. It also will modify the idle point and how it revs.
There are a few videos on You Toobe that show that adjustment, but most just set it back to the stock location for that screw head.
APD
Jan 31, 2023 08:03 PM
holeshot440
Feb 24, 2007 11:48 PM
JonR
Dec 11, 2006 09:04 AM
busted
Feb 16, 2006 08:49 PM
PurNLoud
Jan 11, 2006 10:52 PM
