low idle at startup
when I start up my 12 valve, it has a very low idle, but when it warms up the idle gradually increases, I've adjusted the idle, and it does the same thing if I have it set at 700rpm it will warm up and be around 800-900RPM. the lift pump is new, injection pump was rebuilt not long ago, and I've got 75hp ddp injectors.
an Ideas, or is this normal |
mine does that too, 400 rpm at cold start 600 warm. then back down to 400 if its over 110F I always figured it was the thick oil and less effecent of a cumbustion burn+ mechanical throttle without any electronic idle control
Back off the gov. springs a click, then readjust the idle.
Mine is the same way, regardless of "cold" starting temp, will be about 200 rpms less then warm engine idle. A few seconds with foot on the throttle gets it closer pretty quick.
same thing cold its about 400-500 and warm 600-750. Just is Cold, is normal ive come to realize.
Seems most mechanically injected diesels do this...nature of the beast. No computer to compensate for a cold engine and cold start to advance more fuel.
My P pumped Cummins has always done this. Figure it is normal. I also have to apply a touch of throttle to get an immediate start, otherwise it turns over a couple of times like an older gas engine. The VE pumped Cummins had neither of these issues.
Originally Posted by eng208
(Post 3148302)
My truck does the same when cold...I thought that was normal...I have a manual high idle cable for warm up ...
(Post 3148302)
(Post 3148323)
Originally Posted by Tate
(Post 3142061)
(Post 3148385)
Or adjust the governor springs and idle and it fires up immediately. Seems like a simple solution.
I've been down this road already, argued about it in another thread somewhere. Tate has the answer, and it is simple. |
(Post 3148385)
Tate hasn't been on since Dec 2014, according to his user info - and this thread died in 2012. Do you need a resource for adjusting the idle, or the governor springs? Do a google search for "p7100 pump adjust governor springs", or use the search facility on here to search this forum. This should come up in your search results...
Originally Posted by texasprd
(Post 3383204)
