looking for my abs module
Old Jan 2, 2006 | 11:29 AM
TIMMY22's Avatar
I'm trying to find my abs module, I'm told it's under the dash on the pass. side. I have no manual. I see two plugs on the far right that are easy to get at. they don't seem to plug into a box just other plugs.
96 4x4
Old Jan 2, 2006 | 11:45 AM
plow's Avatar
the one mounted under the dash is the RWAL module i think, the ABS module orCAB is mounted on the front of the ABS valve in the left corner of the engine compartment.
Old Jan 2, 2006 | 11:51 AM
TIMMY22's Avatar
ok, I'm looking for where the two wires from the rear wheel speed sensor connect to.
Old Jan 2, 2006 | 11:55 AM
plow's Avatar
that module is mounted under and in the middle of the dash remove the knee bolster on drivers side to get at it.
Old Jan 2, 2006 | 11:57 AM
TIMMY22's Avatar
10-4 plow, i'll start tearin' into it.
Old Jan 2, 2006 | 12:30 PM
MnTom's Avatar
The AbS module on my '96 is on the hump right under the dash.
Old Jan 2, 2006 | 12:45 PM
TIMMY22's Avatar
thanks plow and mntom. yup, it's right at the hump and very difficult to unplug with gorilla hands.
Old Jan 2, 2006 | 01:31 PM
infidel's Avatar
Sure that isn't the air bag module?
Old Jan 2, 2006 | 02:26 PM
TIMMY22's Avatar
the one attached directly to the hump is the airbag (it says SRS equipped) right on the cover.
that one you would not have to take off the knee blaster to get at it.
the one I unplugged is directly above that one.
i know I unplugged the right one because the abs light went out right after I unplugged it.
Yet, the "brake" light still comes on when you depress the e-brake pedal.
great, I will not have to look at it till I get around to finding my code "10".
some folks swear there more dangerous with the RWAL abs functional.
Old Jan 2, 2006 | 05:02 PM
fschiola's Avatar
Are you sure that a bad stoplight switch isn't causing the lights to stay on? They have 3 different circuits in them and the ABS circuit could be bad and you would still have brake lights.
Old Jan 2, 2006 | 05:27 PM
MnTom's Avatar
Yep, You are right.
DodgeRam24V
0
Jan 7, 2012 06:02 PM
djcheez
Jan 5, 2007 11:51 AM
djcheez
Dec 13, 2006 05:58 AM
dIlLiGaF
Mar 24, 2005 10:00 AM
alltimelow1
May 24, 2004 10:26 PM
