Lift pump
Old Jan 10, 2003 | 07:41 AM
mymaur's Avatar
Lift pump
Dumb question so go easy on me guys! <br><br>Where is the lift pump. Is that what the fuel filter is attached to. Or is it the pump in the tank?
Old Jan 10, 2003 | 09:28 PM
95ramtough's Avatar
Re:Lift pump
How much is the lift pump to replace when you do it yourself? I have a 98 12 valve, should I be worried?
Old Jan 10, 2003 | 09:54 PM
pappyman's Avatar
Re:Lift pump
[quote author=98ramtough link=board=16;threadid=9460;start=0#90854 date=1042255680]<br>How much is the lift pump to replace when you do it yourself? I have a 98 12 valve, should I be worried? <br>[/quote]<br><br>Its not a big problem with 12v motors just keep driving ;D
Old Jan 10, 2003 | 10:14 PM
accordionjohn's Avatar
Re:Lift pump
I just had to replace the lift pump a week ago for leaking around the outer seal to the primer. I had just replaced the main fuel filter and primed the system with the manual prime on the lift pump. All of a sudden, had a steady stream of fuel pouring out onto the driveway. Thought for sure I had not seated the filter cannister properly but instead, found the lift pump to be the source of the leaking as outer seal was bad. Was able to get to the pump and prefilter assy., (both come out together) from the top, even though my reach leaves something to be desired. Once you get the intercooler metal pipe out of the way, and remove the fuel filter cannister, it's not too bad. Just had a slight problem getting the pre-filter and lift pump assy., up all the way to the block as the cam inside the engine was on high end, holding off the pump. Had to bump engine over so the pump push rod would contact the low end of the cam and then the pump went up to the block OK. Like another member stated, holding these 2 parts together without losing one of the bolts or gaskets is a little difficult while trying to re-install. The pump and gaskets ran around $180 from Cummins.
Old Jan 10, 2003 | 11:08 PM
dalton4's Avatar
Re:Lift pump
If my memory is correct, I read a post on the other sight were a member had fuel leaking from the pump prime bulb and repaired it with a new o-ring. Worth a try if pump is otherwise ok.
Txwelder
Nov 26, 2025 01:53 AM
Txwelder
May 19, 2005 06:10 PM
Yukon Dodge
18
Jul 1, 2004 10:08 AM
Puke
May 22, 2003 12:18 AM
Haulin_in_Dixie
47
Nov 17, 2002 09:30 PM
