Ive sprung a major leak!
Old Nov 24, 2007 | 03:23 PM
one54ton's Avatar
Angry Ive sprung a major leak!
Got the trans pan fixed only to fing a massive puddle of ATF under the truck. Im thinking rear main seal but I cant pinpoint an exact location. Anyone else have this problem?
Old Nov 24, 2007 | 04:40 PM
dieseldemon's Avatar
Fixed trans pan? What did you do to it? Are you talking about the rear main seal in the engine? If so it will not be tranny fluid. More info
Old Nov 25, 2007 | 12:22 PM
Buckshotram's Avatar
1st i would spray some engine degreaser up underneath everything and clean it off very good. Your thans fluid heat exchanger(i believe thats what its called) is located under the air filter and towards the rear of the moter. It could be leaking from there and would probally fall near the rear mail seal of the moter. I would also check all trans lines dodge has wonderfully (im being scarcastic) designed trans lines that have clips on some of them that are not very good. If you can clean everything off good lay up under there and see if you can pinpoint the leak. Hope this helps. Also check the lines going to heat excanger mine rubbed together over the years and started to leak..
Old Nov 25, 2007 | 12:32 PM
one54ton's Avatar
Sorry I meant I put a new gasket on the trans pans. i will get in there with somedegreaser and post what i find. thanks for the replies.
Old Nov 25, 2007 | 12:46 PM
torquefan's Avatar
The replacement pan gasket from Dodge is a reusable unit made from plastic with a fine rubber sealing bead on each side. It is a decent unit, but will leak if there is any damage or distortion on the flange of the pan. You may need a new pan, or an old style gasket in this case.
Old Nov 26, 2007 | 08:16 AM
kawi600's Avatar
pan gaskets are really sensitive to overtorque. maybe you have to replace the gasket again?
Id spray a bunch of carb cleaner around there to get the oil off and run it to get it pressurized and see where the oil is coming from. Could be the cooler lines where they come off the trans?
also check the o-ring on the dipstick where it plugs into the transmission.
Old Nov 26, 2007 | 08:48 AM
kelownadiesel's Avatar
I bet its the coller lines too.Mines done it more than once
Old Nov 26, 2007 | 08:54 PM
one54ton's Avatar
ill check the cooler lines
Old Nov 26, 2007 | 09:24 PM
TIMMY22's Avatar
wait till you see what the dealer wants for those! $$$
Old Nov 27, 2007 | 03:27 AM
wcbcruzer's Avatar
You can get a filter that comes with gaskets from Autozone for $7.
keith1992
Dec 27, 2008 03:27 AM
gwatson
Aug 16, 2007 01:20 PM
mhuppertz
Nov 15, 2006 08:26 PM
MJDiesel
Feb 27, 2006 06:34 PM
BC847
Aug 23, 2005 11:41 PM
