IP gear
Old Nov 2, 2006 | 04:47 PM
chevelle678's Avatar
IP gear
When I pulled my IP gear to change my gear housing (which I still have not got yet) I had the timing marks lined up and made note of where the cam and IP gears mesh each other. I did not realize until after I pulled the gear that there is no key. There is a keyway on the shaft but not on the gear. Can I assume that the shaft has not turned and put he gear back in place when I wrap up my KDP project?
Old Nov 2, 2006 | 06:43 PM
infidel's Avatar
If it was done correctly and the IP was locked at TDC before doing the work you'll be ok. If not it's a flip of the coin...
Old Nov 2, 2006 | 07:28 PM
vette95's Avatar
I did the same thing myself day before when I was tearing down my engine. I talked to a mechanic at the diesel injection shop where I'm getting my injectors tested and he said you just pin the motor and pin the pump at TDC and then install the IP gear. I'll be crash coursing myself on this subject real soon.
wadecool
Nov 13, 2006 12:37 AM
JohnInNH
15
Sep 3, 2006 08:22 AM
mhuppertz
Aug 19, 2006 09:17 AM
trout74
Aug 29, 2005 06:25 PM
Hummin Cummins
Dec 25, 2002 12:29 AM
