Injector pump timing.
OK I am NEW. I have a simple question about timing marks on a 4 BT ***. I imagine same as a 6BT. I installed a Cam shaft and I need the timing marks for the injector pump gear to line up with the Cam shaft. I cant seem to find it in my books at home. They explain how to remove end install just the pump without disturbing the Cam---Inj. pump gear. Help. Phil
Let me look to see if I can find the illustration, as for the gears, you lust line up the marks, timing is a different issue though.
908 Bosch Injector Pump
I have a Bosch INJECTOR PUMP # PES6P 110A 120 RS 3290. It has 908 Bosch on 1 place and the numbers above. Can anyone decipher this number please? What year Dodge will it fit? Is it for a 6 cylinder? Any help appreciated.
Thank you
Thank you
TJ0993
11-08-2007 10:27 AM
2500TurboDodge
05-23-2005 12:43 AM
