Injector pump solenoid?
Anyone know if it can be purchased seperately, dealer says must but the whole gettup at $2700, hoping I can just replace the broken part and not the good parts. this is on a '95 ctd, manual
If its the shutdown solenoid, take it apart and clean/lube it. then try the relay. These are reliable units, rarely go bad. You can replace it seperately, easy job, tell the dealer he needs a mask and gun!!!!!!
As Racer said take it apart and clean. You may have to replace the rubber boot if it's falling apart.
The solenoid is the single most often needlessly replaced part on a 12 valve. The dealer loves to replace them when throwing parts at a problem. Unless the solenoid is visibly burnt up on the outside the problem lies elsewhere.
thanks everyone, it is the one on the back of the injector pump, top side three wire plug, red/white/black
the top is melted at the plug
$2700 was for the entire assembly
if you pull it up manually it works fine so we'll see if fixing this one works first
many many miles on the truck and this is the first real problem other than the wires burning up so we'll see
Thanks again yall
Thanks again yall
I have one off of some sort of kubota engine , appears identicle , except the rod is slgihtly shorter , but it can be threaded out to the same length.
CIH also used a very similar solonoid on the 7100 series tractors , and in the 6 cylinder MX series tractors.
TNAF1
15
Apr 4, 2017 09:27 PM
dodgediesel
Apr 15, 2010 09:00 PM
sooty
Aug 6, 2008 07:40 AM
TJ0993
Nov 8, 2007 10:27 AM
gablekevin
Sep 19, 2006 12:12 AM
