NV 4500 fluid
Old Feb 6, 2006 | 05:21 PM
RAW FUEL's Avatar
NV 4500 fluid
I need some NV 4500 transmission fluid. What do I need? Castrol syntorque or Amsoil syn. 75/90 which I read on the amsoil website was a direct replacement. Anywhere I can get it tonight.....
Thanks,
Brian
Old Feb 6, 2006 | 05:32 PM
RAW FUEL's Avatar
OK I just called Advance auto and the guy there told me that they have advance auto ATF+3 and Valvoline ATF+3 and he said that they are direct replacements for Castrol Syntorque. Anyone know if this is the truth.... Wanted to check authority here first
Brian
Old Feb 6, 2006 | 05:47 PM
earl78621's Avatar
Atf+3 Is Automatic Tranny Fluid
Use Cant Use It In A Nv4500 I Run Amsoil In Mine
Old Feb 6, 2006 | 05:57 PM
apache's Avatar
The chevy dealer has the same thing for GM trucks for $24 a quart as opposed to DC charging $34(locally for me). It is said Syntorque is a GL4 not 5. The added zinc in typical gear GL5 oils will eat up the carbon fiber syncro rings. Personally I wouldent chance anything but Syntorque.
Old Feb 6, 2006 | 06:24 PM
RAW FUEL's Avatar
I'll try the chevy and Dodge dealers and get the correct stuff.
I thought that the ATF+3 was auto trans fluid, bonehead at Advance must have told me wrong or misunderstood me.
Thanks,
Brian
Old Feb 6, 2006 | 06:59 PM
infidel's Avatar
Make sure to get Castrol Syntorq not Syntec, it won't work
Old Feb 6, 2006 | 07:18 PM
jughead's Avatar
fluid
check with quaker state. they have the lube that i used. it is water white. about 1/2 half dealer cost
Old Feb 7, 2006 | 10:22 AM
robert chilton's Avatar
The local autozone carried a fluid that is supposed to be compatible. It is a penzoil fluid with the chevy and GM part number right on the front of the bottle. Says it is good for a NV4500. That is what I used on mine. I cant remember what name it went by and I have been meaning to get back to check to see which syn it was. Going from memory it was $6-8 a quart. May be worth looking into.
Old Feb 7, 2006 | 01:13 PM
RAW FUEL's Avatar
I went by the Dodge dealer and got the NV4500 fluid. It listed for $22.90 a quart but sold it to me for $15.30 a quart. What a deal
It took 1 1/2 quarts to top my tranny off. Next time I'm in the Zone I'll check to see if they have what you found. Thanks.
Brian
Old Feb 7, 2006 | 02:19 PM
apache's Avatar
Thats a steal compared to my local dealer. Dodge wanted something like $36 a quart. My local oil supply house has 16 gallon drums for $380. Be curious as to what penzoil has thats compatible. I will say there is still the factory sticker on my trans that says" use of any other fluid other than Castrol Syntorque will void all transmission warranty".
Old Feb 7, 2006 | 04:27 PM
Pretty sure that it was pensoil. Comes in a yellow plastic container with black writting on it. Quart bottle is shaped like a gear lube container. Should be in the same section.
Old Feb 7, 2006 | 06:26 PM
Well I got energetic enough to run to the parts store. It must have been penzoil syncromesh. I didnt see any listing on the side of the bottle about the NV4500 this time but it did have a bunch of part numbers on it. Anyone know if this is good for our trannies for sure?
Old Feb 7, 2006 | 06:36 PM
RAW FUEL's Avatar
The bottles I got this morning from Dodge says for use in all NV4500 transmissions, 75/85 synthetic GL-4. What did the pennzoil bottle say?
If you need part numbers I can get them from this Dodge fluid. Other Dodge dudes/dudettes reading may have them memorized.
Brian in NC
Old Feb 7, 2006 | 06:59 PM
I know that when I bought it that it listed the 4500 so I am not worried. Tranny shifts better and doesnt grind going into third like she used to either. Whatever it is the stuff has been working for 8 months. Synchromesh was the only penzoil they had on the shelf today so I am guessing that was it. A quick search of the penzoil site says it is the wrong part number though. Looks like it might be best to just avoid the pensoil unless you take the GM or mopar numbers to the store with ya.
fluty118
Nov 26, 2007 06:03 PM
Tommy93w350
Jun 26, 2007 04:42 PM
2500
Oct 2, 2006 09:14 PM
icrider
Sep 27, 2006 03:10 PM
v8440
Apr 10, 2006 04:05 PM
