p pump shutoff solenoid leaking motor oil
Old Aug 4, 2008 | 08:01 PM
sooty's Avatar
a buddies pump is leaking profusely, but in his words, "it works good", he pulled on to my driveway, with 10 acres of other dirt parking options, and left a sizeable pond, that would scare hazmat, how are these seals installed, from the arm outside(removeable) or the inside(not removable) or is it an o-ring, where the shaft has to be removed, if the pump has to be removed, is it possible to just change the seal, or do i need to break it down, what else would i need to focus on with it apart, joe.
Old Aug 5, 2008 | 07:24 AM
Common's Avatar
I really don't think the shutoff solenoid leaks motor oil.
Are you sure thats what is leaking?
Did he leave the allen plug off when adjusting his starwheel or loose the washer for it?
Old Aug 5, 2008 | 08:49 AM
sooty's Avatar
leak
looking at the side, below the solenoid, the linkage arm goes into the pump, its that seal, the fuel plate cover is above the area, and im wondering if it allows any access, im understanding, the f.p. area is fuel, the lower area at the seal is oil pressure thanks for the reply, joe
Old Aug 5, 2008 | 09:42 AM
John Faughn's Avatar
Thats not the solenoid , also telling us what he has helps , the better question/info , the more quantity & quality of answers .
We have to read into your question to assume what he has , a 12v and the shut off linkage ?
I haven't been into that part , so can not tell ya , but wanted to see what was happing , then after reading wanted help get you some answers , I suspect that some read the lack of info and just pass by .
Old Aug 5, 2008 | 10:36 AM
xzaq103's Avatar
Im thinking its the two bolts that hold the afc down and the solenoid on are stripped or might even be missing. or there just not tight. if there not tight it will eak a lot of oil. Make sure there tight but DO NOT over tighten them. They strip easy.
Old Aug 6, 2008 | 01:19 AM
cstroup's Avatar
My afc housing became loose on my 12v and leaked oil sumthing terrible. Gave the underside some rustproofing
Old Aug 6, 2008 | 07:40 AM
impmouse's Avatar
under the afc housing theres a rubber seal, over time they get flaten out and will not seal ,i just replaced mine it cost me more for shipping than the seal ,,, its a flat sqaure cut seal .any pump shop should have those seals that rebuilds p-pumps
adamroofer25
Jun 24, 2004 05:54 PM
Palmetto_kid
15
Nov 17, 2003 02:47 PM
NOTSTK
Oct 7, 2003 09:13 PM
doomgaze
Feb 12, 2003 05:55 AM
RamTuffGirl
Dec 12, 2002 11:46 PM
