Different hp/tq ratings for 12v?
Old Aug 5, 2008 | 01:24 AM
wcbcruzer's Avatar
12 Valve B
* 160 hp with 400 lb-ft
* 175 hp with 420 lb-ft - Dodge only
* 180 hp with 420 lb-ft - Dodge only
* 190 hp with 475 lb-ft
* 210 hp with 520 lb-ft
* 215 hp with 440 lb-ft - Dodge only
* 230 hp with 650 lb-ft
Got that off www.dodgeram.org.
I'm curious as to how the same 12v engine can have 210 hp and 520 lb-ft torque in one case and 215 hp and 440 lb-ft torque in another. Is it timing? Different internals? Just curious to know what causes the difference...
Old Aug 5, 2008 | 09:41 AM
infidel's Avatar
Mostly timing because in non onroad applications the same engine doesn't have to follow emissions laws.
I've seen marine 5.9s where the stock timing is 21°.
Old Aug 5, 2008 | 02:33 PM
Willy91's Avatar
possible cam differences as well.
Old Aug 6, 2008 | 02:11 AM
Tate's Avatar
Would it not also be plate differences? I thought for a while you could get a HP upgrade from Dodge to bump it to 230hp and 600 or so ft-lbs?
Old Aug 6, 2008 | 10:49 AM
bmoeller's Avatar
Wouldn't need to change the plate. They can be slid forwards and rearwards to adjust the hp.
They may have different governors or spring settings, too.
May have a different turbo.
Old Aug 6, 2008 | 11:18 AM
66gaza's Avatar
I have a 210HP/520TQ motor it has a HX35/14WG and timing is 12.5*, I do not know what shape the fuel plate is yet but I have a No 10 to go in but it is only supposed to up the power to 230HP/630TQ. It is a road engine and so is a 230HP/630TQ which I could have bought enstead but I preferred the condition of the one I got. The 230HP/630TQ motor still had a HX35/14 on it but not sure about the timing, The pump has to be the difference could be DV's or the cam in the pump.
Gaza
Fisherguy
29
Aug 6, 2009 12:45 PM
LOP223
21
Apr 8, 2008 08:51 PM
Dave88LX
Dec 8, 2006 02:53 PM
andyr354
Aug 15, 2006 11:05 AM
latitud_rt
Oct 23, 2002 10:19 AM
