Front Spring Numbers - different ratings
Old Oct 22, 2002 | 09:28 AM
latitud_rt's Avatar
I was crawling around under my new truck and noticed that the tags on the front springs had numbers on them. One was a #39 and one was a #46. I had found a spec page earlier that listed ratings of each of these springs and I decided to compare mine. Turns out the #39 spring is rated at 1688 lbs and the #49 springs are rated at 1854 lbs. I thought this was strange to have two different ratings so I called the dealership to verify. After three different attempts, I found a compitent (at least over the phone) parts person who took my VIN number and checked the specs. Sure enough the springs are correct even thought they have different ratings. Go figure???? ???<br>
Old Oct 22, 2002 | 12:21 PM
phox_mulder's Avatar
Re:Front Spring Numbers - different ratings
I think the reason is two-fold.<br><br>1- Engine torque. The engine when turning twists to one side, so they put a heavier spring on that side to compensate.<br><br>2- Driver weight. DC figures half the driving around is done with one person in the vehicle, heavier spring compensates for extra weight on one side.<br><br><br>opinion, speculation, not based on fact.<br><br>phox<br>
Old Oct 22, 2002 | 12:52 PM
Shovelhead's Avatar
Administrator / Scooter Bum
In addition you're carrying up to 35 gal of fuel on the left frame rail. Diesel = approx 7 lb/gal.
Old Oct 22, 2002 | 01:02 PM
I knew there was something else.<br><br>phox
Old Oct 22, 2002 | 02:15 PM
BigBlue's Avatar
Here's a question for ya. If the springs are different ratings for each side, when you go and buy a leveling kit that includes new springs, are the new springs set up for that, or are they both the same?
Old Oct 22, 2002 | 03:04 PM
Shovelhead's Avatar
[quote author=BigBlue link=board=5;threadid=6144;start=0#56024 date=1035314105]
[/quote]
That would be a real good question for the &quot;Experts&quot; at the company of your choosing.
Old Oct 22, 2002 | 07:29 PM
PaulG's Avatar
My truck has the same 46/39 spring combo. I called Skyjacker the other day with some questions about their 2.5&quot; front springs. I happened to ask them if they were the same rate for each side, and they said they were. When I told them that the factory uses a stiffer front spring on the driver's side, the guy said he had never heard of that. I don't know if it really matters or not. On my truck, the passenger side measures 3/4&quot; lower to the top of the fender lip than the driver's side. That makes me think it might be better if they are the same rate.
Old Oct 22, 2002 | 07:39 PM
Shovelhead's Avatar
[quote author=Paul Guthrie link=board=5;threadid=6144;start=0#56159 date=1035332985]
[/quote]
Is that with an equivilent weight in the driver's position?
Old Oct 22, 2002 | 08:07 PM
danlit's Avatar
All those #s are Kg/mm of weight you can convert it to lbs/in.<br>They are different for many reasons.<br>If you do switch to aftermarket springs, you`ll notice that most are the same left/right the reason is they make them over (stiff) so you don`t notice a difference L to R.<br> It all works.<br>If you want take your 46 and move it to the other side of the truck and buy one 54 this will equal out weight transfer and also raise the truck about an inch.<br> Hope this helps anyone thats interested.<br> Danny
Old Oct 23, 2002 | 09:46 AM
TXBobcat's Avatar
<br><br>Latitud - Is that spec page you were talking about online? If so do you have an address? I was curious to know what the ratings are on the following springs:<br><br>171AA<br>172AA<br><br>077AA<br>078 AA<br><br>Dealer I talked to said they don't know and can't look it up.<br><br>Thanks...Bob
Old Oct 23, 2002 | 10:19 AM
latitud_rt's Avatar
Here is where i got my info, but it only list by the tag #'s on the spring.<br><br>http://dodgeram.org/tech/specs/springs.htm<br><br>Hope this helps,
jhenson
Sep 8, 2012 10:37 PM
Fisherguy
29
Aug 6, 2009 12:45 PM
wcbcruzer
Aug 6, 2008 11:18 AM
Dave88LX
Dec 8, 2006 02:53 PM
andyr354
Aug 15, 2006 11:05 AM
