How do you set the idle?
Old Aug 5, 2005 | 08:16 PM
95black2615's Avatar
I'm a diesel newbie. I looked where the throttle cable links up out by the injectors, but I dont see an adjustment screw.
Where is the adjustment at? (the idle is currently at 450 rpm)
Old Aug 5, 2005 | 08:31 PM
plow's Avatar
on my 97 it is down behind the injection pump you can't hardly see it you kinda have't to snake your arm down behind there and feel it and then look around until you see it.
Old Aug 5, 2005 | 08:34 PM
DRM's Avatar
DRM
I *just* picked up a Haynes manual today, but I believe if you look at the end of the throttle cable, follow the linkage rod back towards the fuel filter area. Just below that is a small bolt in a casting boss, with a lock nut underneath the boss.
At least, that is what I gather from a little light reading so far
Old Aug 5, 2005 | 08:35 PM
plow's Avatar
http://www.dodgeram.org/tech/dsl/adj...d_Gen-Idle.htm check this out i hope i got it right.
Old Aug 5, 2005 | 11:08 PM
got it......thanks!
Old Aug 5, 2005 | 11:32 PM
TxDiesel007's Avatar
Where did u pick up the manual for the cummins? i cannot find it ANYWHERE!!
This is vital information that must join my college book collection...
Thanks!
Tx
PS... plow just beat me to the link But not to this.. Welcome to DTR new friend! hope your ram brings you many miles of good service! you are already ahead of the game by puttin it in ur sig, and coming here for your needs many a good fella here and much good information...
Old Aug 6, 2005 | 07:03 AM
berner's Avatar
The Haynes book for Dodge trucks has a whole section on cummins. Genosgarage has them. Another thing you might check out are the CD manuals on Ebay. More info than the Haynes, but not as handy. You can get a DC shop manual from techauthority.com.
On setting the idle: The top of the screw has a tendency to get a groove worn into it from the idle stop. Makes setting the idle a bit touchy.
Old Aug 6, 2005 | 08:20 AM
DRM's Avatar
DRM
Advance Auto had it
Old Aug 6, 2005 | 09:57 AM
TRCM's Avatar
Get the fleet service manual/dodge repair manual...geno's has them....100 times better than haynes or chiltons.
I have one for all of my trucks, and the one for the 97 ctd is about 2 1/2 inches thick.
It is well worth the extra money.
Old Aug 8, 2005 | 02:01 PM
SoTexRattler's Avatar
I agree! Factory manual is worth the money! Best out there.
Before you try to adjust, crawl under the truck and look UP to the rear of the inj pump and get familiar where the adjustment is, as it is best adjusted by "feel" from the top.
Underneath you'll see a high speed stop screw with a seal on it .. That's NOT the one you want to mess with. The one you want is the one the throttle arm is resting on. It will be the most rearward screw and jamb nut on the pump.
It takes two 10mm wrenches and it won't take much turning at all to bump the idle up!
The hardest part is getting the jamb nut retightened without moving the idle screw.
It may take you a few stabs to get the right RPM.
Last month I adjusted mine to keep from stalling with A/C on and I wound up getting it a little too high(~925rpm).. The engine was much too warm at the time to be very touchy-feely down there and I called it good enough until Fall.
Keith
Old Aug 8, 2005 | 04:04 PM
I was already makin my own with all the printouts i have
from this site, genos, dodgeram.org and many others... there really is enough info out there to make ur own.. Besides mine is on order from genos, thank you fellas!!
Tx
ClayBob
Aug 7, 2009 09:41 AM
PsRumors
20
Mar 9, 2006 09:59 PM
ajpulley
Nov 23, 2005 07:24 PM
Dodgezilla
Sep 23, 2004 04:21 AM
