GEN light came on.... then off
Old Dec 19, 2007 | 01:10 PM
cmac's Avatar
so my GEN light came on while i was going onto post this morning and at the same time my voltage gauge dropped drastically, so i turned of the radio.... heater.... lights etc. and got work just fine. when i left at noon the light was off and the gauge read fine. i turned on all my lights and every thing else i could think of to draw power and everything looked ok. any ideas on why this might have done that?? it really has me stumped. thanks in advance!
Old Dec 19, 2007 | 04:16 PM
lifer's Avatar
It is your brushes on the alt. The shaft gets worn and makes it so that sometimes they make contact and some times they dont. It wont go away by itself. You will either need to put new brushes in (about $15) or get a new alt. The brush change will buy you some time but they will wear out quicker because the commutator is already worn where the brushes make contact. If you are handy and have a lathe you can recut the shaft and it would be fine. I hope this helps you.
Old Dec 19, 2007 | 04:32 PM
sawmill's Avatar
Make sure you battery cables are tight and clean I had the same problem.
Old Dec 19, 2007 | 07:26 PM
MikeR's Avatar
Brushes. same symptom happened this year on m 95.
Old Dec 19, 2007 | 08:35 PM
roughstock's Avatar
Having same problem with my 95 chevy PU. New battery and alt an still same problem. LOW Volt gauge and hard starting. Maybe armature? in starter. Maybe be bad cables?
Old Dec 20, 2007 | 02:12 PM
cmac's Avatar
well thanks for all the input. guess i'll look at getting a new alt. so i have one if it happens again. it's just wierd that it hasn't done it since.... i dunno.
Old Dec 20, 2007 | 03:01 PM
lifer's Avatar
If it is the brushes it will get worse over time mine did it for 3 months before I put brushes in it. It would be worth checking over the wiring looking for a bad or loose connection. When mine would do it was when the engine was cold and then intermitten when worm. When it was warm usually a quick rev of the engine would get it working again untill it got real bad then I figured I better fix it before I had a dead battery.
Old Dec 20, 2007 | 05:21 PM
GAmes's Avatar
Don't get too hasty about getting a new alternator. If there is a large, continuous load (like the grid heaters) the PCM will kick the alternator off line, and reset when you start the engine the next time. When you start it in the morning pay attention to the grid heater cycling. If it stays on (low voltage displayed) and doesn't cycle off you may have a malfunctioning relay or two.
Old Dec 22, 2007 | 06:01 PM
cmac's Avatar
well it still hasn't happened again. and i disconnected my grid heater from the battery as they stayed on one day and killed my batteries. got the new relay that mounts on the inner fender but that didn't work so i left them unhooked. i checked out all the wires and all seems well.... could it have been condensation or something like that??? it was cold as heck and raining the day before it happened and just started to warm up when i was headed to work. just an idea.....
longhauler
15
Jul 5, 2010 06:50 PM
Ridiculous
Jan 3, 2007 05:40 PM
big jimmy
Jul 17, 2006 11:54 PM
tobyw
Aug 6, 2003 07:37 PM
RHC
May 7, 2003 11:16 PM
