Fuel Shutdown Solenoid Issues
Old Dec 7, 2007 | 03:45 PM
Bersaglieri's Avatar
My truck started having issues starting a while ago. I tracked it down to the fuel shutdown part of the motor. Here is how I solved the problem temporarily. I turn the key to the on position, get out of the truck, manually lift the plunger on the fuel shutdown solenoid, get back in and start the truck. Works everytime, but it's getting really cold and we got 6-7 inches of this week.
So I dont think its the solenoid, cause once is up, the truck doesnt shut off on its own, but will shutdown when the key it turned off. Seems almost like it slowly but surely started having problems lifting itself into the up/on position by just turning the key. But if you do it manually it works everytime.
Any tips? Do I need a relay possibly?
-Dustin-
Old Dec 7, 2007 | 04:31 PM
Danavilla's Avatar
The fuel shutdown solenoid actually has 2 separate coils. One pulls the lever up as you start the truck and the other holds it there until the key is turned off. Sounds like the lift coil is failing. Test to be sure you have power at the contact with the key in start position.
Dan
Old Dec 7, 2007 | 04:32 PM
John Faughn's Avatar
The 70 amp relay that pulls the solenoid , there are 2 different circuits , one is working , the hold , when you lift , the other is not , the pull .
Old Dec 7, 2007 | 04:37 PM
C2O's Avatar
C2O
the solenoid is fine more than likely its the relay it sounds like but to be sure check your voltage while cranking if nothing you need a relay.
Old Dec 7, 2007 | 05:50 PM
infidel's Avatar
Also check that the blue wire at your driver's side battery's positive isn't corroded.
ndtguy1
Nov 27, 2003 09:48 AM
mechanic
24
Sep 26, 2003 11:46 PM
Fishinghaoliboy
Jun 28, 2003 08:33 PM
Numero Uno
Mar 23, 2003 08:14 PM
taz1456
Oct 27, 2002 09:01 AM
