Fuel leak
Fuel leak
On my 97 dodge I have sprung a leak, its coming out from behind the pre filter/fuelheater. I deleted the heater trying to fix the problem but that did not fix it. It only leaks when its running and its for sure not coming from the main filter housing. Its really hard to see down in there. Any thoughts?
Sent from my DROID4 using Tapatalk 2
Otherwise you need 2' of 5/16" id hose just to replace the line in red below.
Yes you can. I just cut my quick connect end off and clamped around it. Mine ended up being the return line right at the back of the pump was leaking. It had a hole in it. Its a real pain to get in there to change it out . My truck has a flatbed on it and made it easy to get to the top of the tank. If you have a bed it could mean dropping the tank or pulling the bed.
ZPOD
18
Sep 23, 2010 10:37 AM
superdiesel9
Oct 25, 2009 07:56 PM
donhov
26
Jan 6, 2006 07:29 PM
Lightman
16
Jan 21, 2004 10:46 PM
