e brake questions
Old Jan 26, 2003 | 10:30 PM
oldred97's Avatar
e brake questions
I have a bd brake as my sig says. I'm not as impressed as I once was with its holding power. My question is how can I tell if I have hd valve springs or not. Since I didn't put the brake on myself (done prior to purchasing by previous owner). I don't know what it has under the valve covers and was wondering how to tell what hd springs would look like compared to stock springs. I know under valvers need them to give max holding power and was wondering if this might be the answer to my weak e brake.
Old Jan 27, 2003 | 12:30 AM
Roger rodbolt's Avatar
Re:e brake questions
I suspect that your pressure needs adjusting on the e-brake. Have you put a guage on the e-brake? Check the idle pressure, then drive it and see how the pressure registers while downshifted on a hill with the e-brake engaged. A cracked exhaust manifold, leaky gaskets etc. will cost you braking power. If it's a remote mount there are other issues too. <br><br>Strong valve springs allow you to adjust the BD brake to a higher pressure, though I think you will need to change an internal spring to get max performance on 60lb valves if you now have the 35lb brake. Larry
Old Jan 27, 2003 | 12:31 AM
TBGH's Avatar
A 60 lb. valve spring (exhaust) has a barrel shape compared to the intake spring. You will see the difference. If there is no difference, then no HD exhaust valve springs.<br>TBGH
Old Jan 27, 2003 | 02:41 PM
oldred97's Avatar
How do I check the pressure and how do I know if my brake is a 35lb brake?
mr T
Oct 16, 2005 07:38 PM
2500TurboDodge
Jun 28, 2005 09:52 PM
ddestruel
Apr 6, 2005 11:26 AM
wvcowhauler
13
Apr 3, 2005 11:39 PM
