Dexcool Antifreeze
Old Oct 23, 2004 | 11:23 PM
myk00l's Avatar
Question Dexcool Antifreeze
HOW DOSE DEXCOOL ANTIFREEZE STANDUP WITH THESE CTD?
Old Oct 24, 2004 | 01:59 AM
Yamadad's Avatar
I know I'll probably get flamed, but...... I use it in mine with no problems and no complaints. I've used it for years in a variety of vehicles and have been totally satisfied with it.
Old Oct 24, 2004 | 06:02 PM
myk00l's Avatar
I was wondering because the guy i bought the truck off of just changed the antifreeze and thats what he put in it .
Mike
Old Oct 25, 2004 | 11:31 AM
cumminsboy's Avatar
Dex-Cool evaporates pretty fast also. cumminsboy
Old Oct 25, 2004 | 11:40 AM
SHARPMACHINE's Avatar
I think that it is more abrasive. In chevy's it causes havick with plastic intakes on the 3800 and upper intake gasket's on all of the other v engines. Besides what goes bad with the green stuff??
Old Oct 25, 2004 | 11:56 AM
ddestruel's Avatar
From: Used to be missoula, montana: Now in Sonoma County California
I ran the CAT extended life, same color as the Dexcool, i assume it is a similar synthetic but darker. 250k miles no issues.
Old Oct 25, 2004 | 08:55 PM
kd460's Avatar
Might want to check out the following links. Turns out prestone (and all the other major brands including the wal-mart brand) have a new G-05 "Universal Coolant".
Sounds like pretty good stuff. I'm not knocking Dex-cool. I've used it without any trouble in my vehicles for the last 10 years, including my Dodge truck, but I like the new stuff being compatable with all the others. Makes changing the type of coolant easier, and seems like this new stuff is more "metal" friendly.
Also be advised that all the anti-freeze made in the US comes from the same plant/place. So don't hesitate to buy the Wally world brand. It's the same stuff as all the other major brands for about 2 bucks a gallon cheaper.
http://theoildrop.server101.com/ubb/...;f=37;t=000197
http://theoildrop.server101.com/ubb/...;f=37;t=000180
http://theoildrop.server101.com/cgi/...DaysPrune=1000
There is some good info in the above links, use distilled h20 (can pick up at wal-,art while getting your coolant), and mix exactly 50/50. Don't forget your heat exchanger holds about half of gallon in addition to the block. Kevin
Old Oct 26, 2004 | 09:40 PM
RBFD415's Avatar
There is a guy with a radio show called the "Car Doctor", in the New York City area it's on Sunday Mornings at 10 AM on 710 (AM) WOR- anyway he seems like a straight shooter- every week it seems this guy bad mouths Dexcool- for a variety of reasons (engine problems). Based on what I've heard him say I'd think twice before I used it. The Car Doctor is heard on stations all over the country- you might want to check him out.
Old Oct 26, 2004 | 10:05 PM
myk00l's Avatar
thanks for the info guys. mike
Old Nov 1, 2004 | 10:31 PM
RBFD415's Avatar
I just found some more info on Dexcool- per the book I read it's big claim to fame is extended life- about FIVE YEARS, however- there's A BIG BUT! It only delivers the 5 year life when used from day one at the factory! When it is added latter on in the trucks life, it does nothing to extend the change period. It coats the coolant system when used from day one- this bennifit can NOT be gained from changing to Dexcool latter in the life of the engine. So says the book.
Old Nov 2, 2004 | 12:59 AM
98 2500's Avatar
only reason i would use dexcool is if i absolutly positively had to. Otherwise, its for the birds
Old Nov 2, 2004 | 09:44 PM
marv h.'s Avatar
hey kd460, thanks for the info. In a mix of 50/50, how low of a temerature will the coolant/water mix protect from freezing? Will this mix be safe at 40 below? I thought I needed to mix more antifreeze in to boost it up for colder temps. Thanks, marv.
HD2500
Oct 31, 2008 08:23 AM
dodgediesel
Sep 23, 2007 03:27 AM
myk00l
0
Oct 23, 2004 11:10 PM
drecu
May 4, 2003 12:31 PM
Fillerupsonny
Oct 8, 2002 01:22 PM
