Antifreeze/Coolant....
Old Apr 30, 2003 | 08:38 PM
drecu's Avatar
hey guys i'm gonna be changing mine soon on the truck &amp; on our van &amp; was wondering what you all use &amp; like.. I need something that will handle the low temps for the winter sometimes as low as -20 &amp; the summer get's up to about 105 max temp.<br><br>DRecu!
Old Apr 30, 2003 | 11:19 PM
Stamey's Avatar
Re:Antifreeze/Coolant....
I just use whoever's got [glow=orange, 2, 300]orange[/glow] antifreeze. I like the color. ;D<br>Everybody's got [glow=green, 2, 300]green[/glow].<br>As far as I know, brand doesn't really matter, as long as covers the expected temperature range you'll be running it in.<br><br>Chris
Old May 1, 2003 | 12:35 AM
KATOOM's Avatar
I got mine at the Cummins store. Fleetguard. 50/50 mix. No messing with water.
Old May 1, 2003 | 06:38 AM
pappyman's Avatar
I use Fleetguard anti-freeze...I keep it at -35*
Old May 1, 2003 | 08:09 AM
BarryG's Avatar
Rotella also makes a premix for our engines. You really just need to make sure it is silicate free so check the bottles that cuts the choices by half or more.
Old May 1, 2003 | 10:34 AM
me4osu's Avatar
I use Rotella ELC (Extended Life Coolant) pre-mix. It is supposedly good for 600,000 miles with an extender added at 300k.
Old May 1, 2003 | 03:56 PM
phox_mulder's Avatar
[quote author=KATOOM link=board=7;threadid=14232;start=0#133861 date=1051767340]
[/quote]
I 2nd that opinion.
Why mess around with others that might be more harm than good for our engines.
Get the stuff made by Cummins for the Cummins.
(ya, ya, ya, it's more expensive, but so is the engine)
phox
Old May 1, 2003 | 04:54 PM
Monty's Avatar
I use the Fleetguard ES Complete (blue in color) in mine. 50/50 pre-mix.
Old May 2, 2003 | 12:02 PM
drecu's Avatar
Thanks guys! did not know fleetguard had thier own, also would the fleetguard be ok in a Gasoline Engine also?<br><br>DRecu!
Old May 2, 2003 | 01:20 PM
DRD's Avatar
DRD
One thing to watch is that newer gasoline engines are mostly aluminum where the heavier duty engines have more cast iron. Two different coolant types are necessary.
Old May 4, 2003 | 01:35 AM
jigdog's Avatar
i went to a rad shop last summer and had a flush done and good antifr put in.I had a local diesel shop that did my gauge pak try to sell me that you need to have that addative in the rad but went to cummins and he said onl if you are running a bigger model of cummins that is stock 275hp and a wet liner cyclinders.<br>2kctd lb 4x4 quad.leather,autometer on the post.gettin ready to do 4inch,with a fuel box.
Old May 4, 2003 | 12:31 PM
EricBu12's Avatar
Wal-mart <br>Shell 50/50 mix that is diesel ready and recomended and approved by cummins, cat, and detroit
dodgediesel
Sep 23, 2007 03:27 AM
Palmetto_kid
20
Mar 30, 2005 09:32 AM
FANZDSLPWR
May 19, 2004 10:06 AM
Fillerupsonny
Oct 8, 2002 01:22 PM
