Damper for '94 12-V
Old Jul 26, 2013 | 10:27 AM
MChevy65's Avatar
Damper for '94 12-V
I ordered a new damper for my '94 12-valve. The original was an 8-inch and was damaged in an accident. I ordered a replacement from Pure Diesel Power, their catalog called for a Cummins 3924435. The original has no part number. When the replacement arrived - etched with the part number above, I compared the two and the new unit is about 9.25 inches. Is this the correct part for this application. I'm pretty sure both are zero balanced and the larger radius is probably a better damper, but I want to make sure before running it.
Old Jul 26, 2013 | 11:43 AM
infidel's Avatar
It looks bigger, will the engine speed sensor still fit?
Old Jul 26, 2013 | 01:21 PM
MChevy65's Avatar
I don't see how it could fit. I haven't bolted it up yet (The engine is not installed in anything). I called PDP and they had no explanation except maybe I had an early production Gen 2 that may have a Gen 1 balancer. He asked for a Engine Serial Number to discuss with Cummins. The p/n I purchased is all they have listed for 94-98 12-V.
Old Jul 26, 2013 | 01:33 PM
jstone44720's Avatar
Just curious. Mine is an early 94 and has the same smallish damper. I have to think you would need a different mount for the sensor to make that work.
Old Jul 26, 2013 | 02:27 PM
Tate's Avatar
All of my 12v and 24v CTD's have the 9-1/4" damper on them. The slots on the ESS are pretty large, so I bet it would still fit.
Old Jul 28, 2013 | 06:21 PM
dieseldemon's Avatar
The small damper was on the 94 95 160 HP engines Cummins changed to the larger damper on the 96 180 and 215 HP engines and yes it will fit
Old Jul 28, 2013 | 06:29 PM
The ESS has a lot of room for adjustment.
It will fit
Old Jul 29, 2013 | 02:50 PM
MChevy65's Avatar
The slots on the ESS bracket are slotted and do accomodate the new bigger damper. Guess I'm good to go. Thanks!
Iron City
Apr 2, 2006 01:38 PM
MrKen
Mar 31, 2005 10:59 PM
bishgeo
Dec 31, 2004 07:25 PM
HOHN
Dec 22, 2004 04:53 AM
tmiller24
Jan 1, 2004 07:19 PM
