Converter unlocking at low speed
Old Feb 10, 2009 | 09:02 PM
Valv's Avatar
My converter is unlocking, then locking back up, then unlock again (and again, and again) when I am at highway speed ( 50mph/60mph) and light load.
I've been serching similar issues but all I found was a ground problem on 2 gens 24 valves with 47RE, I believe I have a 47RH.
Is it same problem ?
Old Feb 10, 2009 | 10:22 PM
Sidewinder's Avatar
Try using the search function and look for TPS (throttle position sensor). I think you will find tons of information to read. This is a VERY common issue. You can clean it or replace it.
Old Feb 11, 2009 | 12:38 AM
96WhiteBuffalo's Avatar
Lots of things can cause this but the 2 most common are the tps (discussed already) and the little switch that causes your brakelights to go on when you hit the brakes. They wear out and activate the brakelight circuit, and kick it out of lockup.
Next time it kicks out of lockup, put your toes under the brake pedal and pull it up a little. If it locks up again, and you can control the lockup that way, there's your problem.
Old Feb 11, 2009 | 05:49 AM
Valv's Avatar
Excellent hints, thank you guys. I will follow them.
Old Feb 11, 2009 | 06:30 AM
Let us know how you make out. The brake switch is about 10 or 20 bucks.
Old Feb 11, 2009 | 10:27 AM
infidel's Avatar
Start here> TPS Testing and Adjustment
Old Feb 11, 2009 | 11:20 AM
Wicked500R's Avatar
TPS.. mine was the same way...I modded the TPS and now locked in 4th on the highway... I can get into the go pedal and roll on at 50 and she'll pull hard up till 75mph without disengageing. Huge improvement!
Old Feb 11, 2009 | 09:52 PM
Valv's Avatar
It is not the brake switch, I will try to adjust the TPS a little, if nothing change I will follow complete instructions by the weekend.
Old Feb 11, 2009 | 10:47 PM
Yellow Yota's Avatar
Stock gov springs or no?
Old Feb 12, 2009 | 05:12 AM
Valv's Avatar
Everything stock on this truck.
Old Feb 14, 2009 | 02:29 PM
Valv's Avatar
I gen no voltage from purple wire. I assume TPS is shot. They are $ 270 at NAPA
$ 175 at Autozone
Any place cheaper ?
Old Feb 14, 2009 | 07:06 PM
Valv's Avatar
Better news, I fixed the broken TPS.
I removed it and turned the rotating part several times (many dozens of times), putting a little pressure inward and outward. Since this is a rheostat based unit, it works just like the volume dial of a radio. Do you remember when every time you turn volume up it was scratchy ? Well to fix it you had to turn up/down many times, it would clean the contacts and eliminate any scratching noise.
Same concept here.
Now my transmission is like brand new, shifts fine, locks and unlocks with no problem, and I saved 200 bucks from buying a new one.
I will study how to open it without breaking it and clean contacts better.
kwillis-a
Jan 24, 2007 09:56 PM
Pendo2006
May 26, 2006 07:09 PM
whosyrdady
Sep 25, 2005 11:07 AM
Foothill-Trader
Jul 17, 2005 11:08 AM
nitrousn
May 10, 2004 12:01 PM
