Check Valve
Old Jan 18, 2004 | 11:40 AM
pancowboy's Avatar
Check Valve
Where is the check valve located on the pump on a 1994 12 valve? Is it on the return line between the injector pump and the motor? I bought one to put in. But eith neck injury I want to do as little looking as possible and just change it if I can. Truck is wonderful. It just needs a bunch of little things fixed. Which I can do.
Old Jan 18, 2004 | 01:10 PM
tmiller24's Avatar
There's a check valve inside the lift pump, but I don't believe there's any others.
Old Jan 18, 2004 | 03:12 PM
Smokee's Avatar
If you mean the overflow valve, ir is at the front of the pump, next to the block. Stuff a rag between the block and the pump so that you do not lose the washer.
Old Jan 18, 2004 | 03:31 PM
pancowboy's Avatar
Overflow valve
Yes I meant the overflow valve Smokee. Thank you for the quick and prompt reply. Since I have been laid up I have gotten to read up on this new truck and this is a great forum with lots of great people and great information. Hope I can help in the future. Tractor mechanic, ex school bus mechanic mechanic. Cummins are tough motors.
Old Jan 18, 2004 | 03:54 PM
tmiller24's Avatar
Oops wrong valve.
Old Jan 19, 2004 | 10:34 PM
kandgo's Avatar
Good source for overflow valves, Marty 517 694 1522 Goodluck,, Rick
Old Jan 20, 2004 | 11:05 AM
dodgeman01's Avatar
if you decide to run 370 or bigger injctors you can shim the over flow valve wth a small wahser which will increase fuel pressure and make the truck run better. A trick I learned from a pump guy.
DM01
Old Jan 24, 2004 | 10:11 PM
mike herron's Avatar
Question turbo boost
How much turbo boost is to much?
Mine is about 40+ running empty and overdrive.
Can this cause blown headgaskets?
Old Jan 25, 2004 | 07:48 AM
infidel's Avatar
All you need is a 3/4'' or 19mm open end wrench, a rag to keep from losing the washers and 5 minutes to replace the OF valve. On some trucks the valve hits the manifold before it will come out, the solution is to grind or file a little bit off the manifold first as has been done in this diagram.
View from front, oil fill at lower left
madhat
68
Oct 25, 2015 08:25 AM
Adam3291
May 2, 2008 10:08 PM
Gary C
Mar 15, 2004 02:53 PM
blownbanana
Dec 10, 2002 12:17 PM
