Boost question
Boost question
I recently installed a 4" exhaust on my truck, did not see a big difference. Before adding the 4", I was maxed out at 32# of boost. Yesterday while driving to work, I had to wood it to get around slow traffic and I noticed 38# of boost. Will this hurt anything? The turbo is stock with the TST elbow. Which way do you turn the allen head screw to back it down ( if needed ). I run empty 98% of the time.
Originally Posted by Desert Rat
I recently installed a 4" exhaust on my truck, did not see a big difference...I run empty 98% of the time.
If your boost elbow is brass with a setscrew, tighten the setscrew to reduce boost. Mine is bottomed out and I get 28 PSI max. No need to produce more than 36 PSI, above which you are just making hot air. Better have a pyrometer if you make more than stock boost (22 psi) or you chance melting pistons.
I'm assuming you have a Cummins diesel? 12 valve? Please add signature info.
Thanks for the reply, I do have a pyro and a 12v. I just don't want to hurt anything running too much boost. I did my sig info and have no idea why it is not there. I have a #8 plate centered and a BHAF.
Thanks, MikeR
Originally Posted by MikeR
If you tighten the set screw you'll completely shut off any airflow to the wastegate actuator. You want to loosen the setscrew.
goose2w1
Jul 23, 2008 10:49 PM
3500_CTD
14
Feb 5, 2008 08:33 AM
TorqueJunkie
15
Aug 30, 2006 09:15 PM
RockcrawlingTJ
Jul 22, 2006 05:11 PM
GTSDave
Jul 8, 2005 09:06 AM
