blue smoke issues after inj pump install
Old Nov 18, 2012 | 04:26 PM
esgdakota's Avatar
Hey everyone!
I pulled my inj. pump off and had them replace the housing cause it was striped out. so why i had it off i replaced the power steering pump and vacuum pump and also the lift pump. I got everything back togeather last night went out today to get it started. once it started i let it idle for about a half of a hour. Normaly it smokes a little blue smoke for about 10 mins then goes away. But now it is smoking all the time. the only time it does not smoke is when i take it for a ride. but once i bring it back and park it and let it idle it starts smoking again. 2 questions! 1 could i have the timing set wrong and that is why it is smoking? the truck is running good no power issues. I had the shop set the timing to 16.5 degrees so all i had to do is pin the pump to have the timing set. 2 I checked the turbo and it does have a little bit of oil resdue inside of it. Could this be the reason it is smoking? the turbo has very little play up and down and left to right. i figued since the truck has been sitting for 5 weeks cause of work and having no time to put it back togeather the oil was sitting in the cylinders. But i had it running all day so i would think it would have cleared up! I just dont want to drive it for fear i will mess it up.
Thanks for all the help!
Old Nov 18, 2012 | 05:46 PM
Tate's Avatar
Timing is not right. Time it properly, shops screw up the timing pin.
Old Nov 18, 2012 | 08:36 PM
esgdakota's Avatar
Tate
When you say time it right you mean by a guage on the pump? why do you think the timing is wrong? I always thought blue smoke means it is burning oil?
I am no diesel mech and please dont think i am questioning if you are right or wrong. I am just trying to learn what went wrong.
Thanks for your help!
Old Nov 18, 2012 | 11:21 PM
Tate's Avatar
Cold diesel exhaust will have a blue colour to it.
I have seen shops screw up the timing pin when resetting them. I had one pump that a shop installed a custom cam in it, told them to pin it at 17 degrees. They pinned it at 17 degrees according to the lift of a stock 160 pump, not to the new cam which they installed. Good thing I have a timing light to catch such things.
Old Nov 19, 2012 | 09:51 AM
esgdakota's Avatar
Tate
do you think it could be out 180 degrees? or do you think the timing is only out by a couple of degrees? I need to order a timing kit do you Recommend any kit? It would have been nice to be able to time the pump with just the pins.
Thanks
Eric
Old Nov 19, 2012 | 10:12 PM
Tate's Avatar
It won't run 180 cam degrees out. I would say it won't run much more than 20 crank degrees out. You can search on here and build your own timing kit. I did mine with a $20 dial indicator and $10 gear puller. The barring tool in my Cummins tool kit was the big money purchase, a whooping $90 for the tool kit. Beats the $250 for the snap-on kit.
Old Nov 28, 2012 | 10:12 PM
esgdakota's Avatar
Tate
I just want to take a min and update you on the process. I took your advice and made my own timing kit useing a drain plug and a digital dial indactor from harbor freight it has mm and inches. i had to buy a dv socket and a $46 barring tool from cummins. and bought a $10 puller from auto zone. when i checked the timing it was at 9.06 mm at tdc. that equals to well over 30 degrees of timing. I turned the motor til the guage read 5.73 17 degrees and poped the gear off. I set the motor to tdc by the pin and bolted the gear back on then i turned the motor over completely and checked the guage agian and the guage read 5.73. i bolted the truck back togeather and wow what a differance. it has alot more low end torque. and no more blue smoke! I just want to take a min and say thanks for all your help! i learn more and more from this site cause of people like you!
Thanks
Eric
Old Nov 28, 2012 | 11:57 PM
Tate's Avatar
Good to hear you got it sorted out.
Old Nov 29, 2012 | 10:35 AM
hounddogks76's Avatar
This is good to hear. I also have the blue smoke, especially when cold. And it sounds like a 7.3 ford when cold....haha Need to get timing checked.
Tarosean
Apr 22, 2016 06:29 PM
BRUISER
Nov 15, 2006 03:20 PM
9 sec camaro
20
Aug 26, 2006 01:30 PM
bensdad_canada
May 9, 2005 10:56 PM
