Blowby while building boost at the track
Old Jul 8, 2006 | 01:23 PM
Bobcat698's Avatar
I went to the track yesterday and screwed up my tranny.. Going to Iowa tomorrow.
Anyways, while building boost at the line, I had a track official say that it looked like I was burning my clutch (obviously I wasn't)..
I saw it as well and I imagine its blowby.
Timing is at 24 degrees.
Vacuum pump leaks oil, and my number 6 cylinder has light scoring..
But I never had this issue before.
Anything else I need to track down?
Old Jul 8, 2006 | 06:10 PM
hotmopr's Avatar
What side of the truck was it on? Could be a exhaust leak???? just an Idea..
Old Jul 8, 2006 | 08:30 PM
PourinDiesel's Avatar
Sounds normal.
You might consider running a breather on each valve cover (like the big boys!)
Old Jul 8, 2006 | 08:34 PM
JD730's Avatar
Just a thought, Could the turbo be pushing air into the crankcase through the oil drain tube?
Old Jul 9, 2006 | 07:33 PM
plow's Avatar
vaccum leak could cause this also.
Old Jul 9, 2006 | 08:33 PM
Willy91's Avatar
Sounds normal to me, what happened to your tranny?
Old Jul 9, 2006 | 08:40 PM
Bobcat698's Avatar
Stuck a clutch in the rear clutch pack.. We think.
Truck is at Daves right now.
Old Jul 11, 2006 | 11:52 AM
Bobcat698's Avatar
Actually, my tranny has a 48RE front clutch drum in it, with the 47RE hub machined to fit it.
I broke the 47RE hub and also the input shaft is twisted 1/4 of a spline!
92smokin blacky
Sep 27, 2011 04:02 PM
CTD2001
Aug 22, 2009 10:03 PM
grecododge
15
Dec 7, 2007 02:25 PM
SmokenRam
Jul 19, 2006 07:52 AM
engcogod
Jul 21, 2005 11:36 AM
