any adjustments to be made while I have the trans pan off
Im getting ready to service my transmission.Since i havent had this truck since new I was wondering If I need to do the band adjustment like on dodgeram.org .I know Infidel said it shouldnt be done evrytime but I dont know if its ever been adjusted on this. should I adjust the line pressure screws and how many turns.thanx for any help
I bought my truck a couple weekends ago. The day after I bought it, I changed the tranny oil & filter. I also adjusted the bands at that time. Truck had 111k on it, and the tranny had been rebuilt at approximately 75k. It didn't look the tranny had been serviced since the rebuild. Yuck!
Originally posted by mytrucksaslug
I heard it was a good idea not to mess with the bands if you dont know exactly what your doing. Will it ruin anything if its done incorrectly?
But to answer your question, I would imagine you could prematurely wear the bands if you don't set them correctly. Just don't do it wrong, and you'll be fine.
IF your tranny is not slipping or giving you any trouble at all, I would just service it and go on, some have caused problems by trying to adjust them, the 94 in my sing has just turned over 100k and the three or four times I know of they have never been out of adustment, Goodluck,,,Rick
I turned the line pressure up on mine just as a last resort to the TC slipping, it isn't really necessary IMO if your tranny and TC are working properly. Do a search for line pressure and you'll catch a thread on how to do it. It isn't hard at all. Just make sure to adjust the TV pressure proportionately.
I don't mean any offense here, but if the manual says to adjust the bands every 24k miles, than I would follow the manual's advice. If you wait until the tranny is slipping or giving you trouble, than I doubt a simple band adjustment will be the miracle cure. It could be, but it isn't worth finding out because you didn't adjust your bands.
You don't wait until after your engine oil is broken down before chainging it do you? Of course not, the damage is now already done.
Originally posted by royta
Kandgo, you're tranny may have not been out of adjustment, but that doesn't mean somebody else's won't be. Not all tranny's are equal when they leave the factory.
I tend to respect Bill K at DTT's advice, don't adjust the bands unless you have to, you are more likely to cause problems for yourself than if you'd left them alone.
The 24k adjustment interval would certainly apply if you hadn't been the one driving the truck for the last 24k and didn't know how it was performing, just like it does for most people who have someone else service their tranny.
The old adage applies- Don't fix it unless it's broken.
My tranny had 30k on it and it worked out to about a 1/2 turn in on booth bands. I DID NOT have a torque wrench that would fit in their, so I improvised with a standard wrench and it worked fine.. just my .002
Bigsmoke3500
Nov 26, 2008 01:42 PM
eng208
Aug 24, 2005 07:31 PM
