adjusting valves
Old Jan 6, 2010 | 12:31 PM
alaskanassassin's Avatar
adjusting valves
I got the procedure to set my valves, have the snap-on barring tool, but have a couple of questions. When you are barring the engine to find TDC do you turn the engine CCW or CW when you are facing the engine? And after doing your first set of valves when turning 360 degrees which way do you turn the engine? Thanks
Old Jan 6, 2010 | 03:10 PM
lifer's Avatar
You always rotate the engine in the same direction that it runs.
Old Jan 6, 2010 | 07:06 PM
Tate's Avatar
The engine turns CW, the barring gear would be CCW. You are also rotating the engine one full revolution, so direction has no effect on the destination.
Old Jan 7, 2010 | 05:05 PM
GAmes's Avatar
It doesn't matter which way you turn the engine to TDC of #1 or #6. Once you find it I recommend you mark the damper. One full turn will give you TDC again to chech the other 6 valves.
Old Jan 8, 2010 | 11:48 AM
Thanks for the help.
Old Jan 15, 2010 | 08:16 AM
Big Deezul's Avatar
fwiw you can turn the motor over using the nut on the alternator pulley
marine4life
Mar 11, 2006 08:36 PM
robox
Aug 16, 2005 07:27 PM
CrewCabCummins
Jan 3, 2005 04:29 PM
Denis
Apr 19, 2004 12:32 PM
Puke
Jun 23, 2003 01:06 PM
