Adjusting Valves
Adjusting Valves
Does anyone have a set of instructions for running the overhead on a '97 engine. I think this is a Cali. truck if that makes a difference.
I have run the overhead on a couple of CAT engines in some Peterbilt trucks, but never on a cummins. The CAT engine have a timing hole in the bell housing that you can pin the flywheel at TDC to adjust.
Is the cummings this way?
Thanks in advance to anyone that can help.
RA
RA
All you should need to know can be found here:
http://www.dodgeram.org/tech/dsl/val.../12_valve.html
