Adding Hydro Boost to my 96
Old Apr 15, 2004 | 05:08 PM
MCummings's Avatar
Rubber line only.
Please don't pinch the metal line.
GREAT thread BTW.
Merrick
Old Apr 18, 2004 | 01:10 PM
torquefan's Avatar
Boner- your 96, if a 2500, should have stock 24 mm wheel cylinders on it. I have never done this on a 2wd, but on 4x4's I upgrade the wheel cylinders to 27 mm units from a ram 3500. With these cyls. the brakes are biased a lot more to the rear. I don't know if I would go to anything bigger.
Old Apr 19, 2004 | 10:37 AM
infidel's Avatar
The Chevy cylinders are about 30mm and work great.
Old Apr 19, 2004 | 10:12 PM
torquefan's Avatar
Holy Cow! That's a big difference from stock. Might have to try that sometimes. Do you find the rear antilock engages a lot when stopping with those?
Old Apr 20, 2004 | 09:27 AM
infidel's Avatar
I haven't noticed any difference with the ABS, just less pedal effort.
Old Apr 21, 2004 | 11:32 PM
Ray,IN's Avatar
Originally posted by infidel
Ray, because the Chevy cylinders are even bigger than the Dodge 3500 ones.
I have a table somewhere that equates cylinder diameter x pressure = force, just a few hundredths inch larger multiplies out too several hundred pounds more braking force.
The bore on the Dodge 1T wheel cylinders is .125" larger than the 3/4T cylinders. How much larger are the Chev cylinders?
Old Apr 22, 2004 | 09:41 AM
infidel's Avatar
The Chevy cylinders are 1.875" (30mm)
stock 2500s are 24mm
stock 3500s are 27mm
The 2500s starting using 27mm cylinders sometime around '98-'99
Old May 15, 2004 | 03:41 PM
AlpineRAM's Avatar
The chevy cylinders have 56.25% more area (meaning more force on the shoes for the same pressure in the brake line) than the older cylinders of the 2500.
The stock 3500 cylinders have 26.56% more area than the older 2500s.
And the chevy cylinders have 23.45% more area than the stock 3500 cylinders.
The relation is the area of the piston x pressure. Pounds per square inch x square inch = pounds.
For a circle it's r x r x pi for the area.
Just flinging in my 2c
AlpineRAM
Old May 15, 2004 | 08:52 PM
infidel's Avatar
Alpine, I assumed a hydraulic force of 500 psi and came out with this. Not sure what the units are or if my calculation is even correct as I mixed mm with psi.
2500 - 24mm=22k (lbs per cylinder force?)
3500 - 27mm=28k
GMC - 30mm=35k
Even if the number I came up with isn't a true unit of measurement it still shows the increase in braking force as the wheel cylinder size increases.
Old May 16, 2004 | 02:00 AM
AlpineRAM's Avatar
For 500 psi the cylinder of an
2500 will act with a force of 350,6pounds on each piston.
3500 with 443,72 pounds per piston
GMC with 547.8 pounds per piston.
AlpineRAM
Old May 16, 2004 | 10:55 AM
Jeremy Cusick's Avatar
I think I'll upgrade to the chevy wheel cylinders sometime this summer!
Old Dec 5, 2004 | 03:49 PM
DustyRock's Avatar
I would like to say thanks to you guys. Not to blow smoke, but give credit where its due. I was poking around to see if I could improve my braking on the 3500. Found it!, with part numbers no less. At that price I am going to do the Chevy upgrade. Infidel, others and DTR Thanks ! I sold my 02 for my 97, the brakes on the 02 that had 4 wheel discs and anti-locks on all four was fantatstic. The 97 is just OK but have to push the pedal alot harder. This should help.
Onemoparnut
Jul 9, 2007 10:59 PM
Flashman
Jun 11, 2007 08:53 PM
Hairy1
16
Mar 31, 2007 04:51 PM
wcbcruzer
Feb 24, 2007 08:33 AM
ironman
Sep 2, 2004 08:36 PM
