97 12v dies when cold why
also the linkage is harder to move
once its warm it starts great
even pushing gas pedal down when cranking some when cold does not help
is the fix the shut off controller could that bind up the linkage?
its a friends non calif 5 speed with 300 k miles
Check to see if the linkage recall has been done here, you will need the VIN
http://www.chrysler.com/webselfservi...m('R')
Also do some maintainance , at 1st I thought idle - but you mentioned giving a little throttle , fuel filter , fuel pressure test , check timing , then go on to more complicated issues , pop test injectors while looking at spray pattern .
my friend had similar symptoms,specially when it was really cold.the reason was broken overflow valve.
http://dodgeram.org/tech/dsl/trouble...ector_pump.htm
If that is the case, then something is wrong. There are many of us who can't plug our trucks in during the winter and have cold started them as low as -20F. It isn't pretty but it works. I don't want to send this thread off track but something isn't right and there are many people on this forum who would be happy to try to help you diagnose this problem.
Its best under those conditions , to cycle the heater a couple times .
But again , by your description , you have some issues , need diagnostics .
vintovka
Apr 30, 2012 12:38 PM
Rockyhud
May 24, 2004 09:44 AM
