94 runs rough when first start.
Old Mar 13, 2016 | 09:12 PM
A.Spagnuolo's Avatar
I have a 1994 dodge 2500 automatic 12v cummins. When it sets over night it is harder to start and runs rough. If you try to put in gear before it warms up a little it wants to stall. It doesnt matter if cold or not. Seems to help if plug in but still not right. Runs good after it warms up some. I replaced fuel filter so far. As far as i know it hasnt had any performance things done to it. It has 166000 miles on it. I dont know what to do. I dont know much about these pumps i know a little about ve pumps on first gen.
Old Mar 14, 2016 | 07:45 AM
DieselDaze's Avatar
Just a few things to check:
1) Idle speed may be too low.
If you press the accelerator pedal (slightly) when you crank it in the morning and she fires right up, then its a good bet that the idle is too low.
2) Check the fuel return line for cracks.
This is a rubber line that takes unused fuel back to the tank. When the rubber cracks, it can cause a loss of prime when the truck sits for any length of time.
If there are no other signs of issues (Smoking, missing, over-all lack of power, etc), then I'd start with the two listed above.
Hope this helps.
Old Mar 14, 2016 | 08:31 AM
I was thinking air getting into the fuel line and letting it loose prime as well.
Old Mar 14, 2016 | 08:44 AM
patdaly's Avatar
In addition to the other things, are you sure your grid heater is working? ( voltage gauge will drop when they are on and lights dim ).
Old Mar 17, 2016 | 08:49 PM
I pushed gas pedal down a little before start and its alot better. Still going to check some other things. I am not sure about grid heater working or not.
Thanks
Old Mar 18, 2016 | 07:23 AM
Thanks
Starting a P-pumped 12Vs it is recommended from the factory to apply a little throttle.
It is written right on the sun visor where they explain how to use the 4x4 system.
They also explain warm up techniques for cold weather.
Old Mar 18, 2016 | 09:55 AM
patdaly's Avatar
Thanks
When you first start it in colder ( say 40 and below ), do you notice your lights dimming and then coming back to normal brightness for a while?
soilsample
Dec 7, 2010 08:05 AM
Ripper406
Oct 8, 2007 12:16 AM
04 dodge diesel
Feb 6, 2007 09:31 PM
wilderness
Sep 17, 2006 08:23 PM
wcso873
Feb 3, 2006 03:11 PM
