Truck keeps dying while driving
Old Mar 7, 2016 | 07:30 PM
Amos's Avatar
Exclamation Truck keeps dying while driving
I have a problem with my 1995 12 valve. Without warning the truck will shut off while driving. Doesn’t happen for a few days then all of a sudden will happen. Sometimes happens on the highway, but also on two lane roads. On the highway it’s done it several times at 70 mph, once around 75, once at 60. On a back road I was going about 50 mph and it also did it. Weather doesn’t seem to matter. Did it in rainy 40* weather, and also today about 62* and bright sunshine.
The truck just dies and you coast to the shoulder. Can then restart and continue driving. Sometimes with no further trouble, other times within 10 minutes it happens again. One time I stopped for fuel after it happened and it sounded like the fuel filler cap was under vacuum when I opened it up – made a hiss or whoosh sound. But this doesn't happen all the time - just once that I noticed.
The problem definitely seems fuel related, but not sure what to check next. I’ve already replaced the fuel filter. Years ago I replaced the rubber fuel lines with the Foster(?) kit but it’s been 8 years probably. Anybody run across this or have any suggestions? Also any chance it could be computer related? I don’t seem to have any electrical issues and the truck has new batteries. Any help is greatly appreciated.
Old Mar 8, 2016 | 10:08 AM
patdaly's Avatar
If it just shuts off like the key switch was turned, then you likely have an issue with the hold circuit.
p7100 trucks have 2 circuits for fuel, a Pull and a Hold, the Pull circuit is a higher amperage one that physically pulls the shut off lever up, then when the truck starts, it disengages, and the hold circuit ( lower amperage ) hold it in place until you shut off the truck.
Good thread to start troubleshooting.
https://www.dieseltruckresource.com/...ooting-279255/
Old Mar 8, 2016 | 05:29 PM
gorms's Avatar
Edit wrong thread!
What patdaly said.
Old Mar 9, 2016 | 04:34 PM
Amos's Avatar
It doesn't do it all the time and I still have headlights, dash lights, etc.
But the engine is stone dead as if the key was turned off. Does that change any opinions? Thanks for the info so far, will take a look and see what I find.
Old Mar 9, 2016 | 07:19 PM
gorms's Avatar
If it happens again before you get to look at it, leave the key on (don't try to start again) and go see if the plunger on the shut down solenoid is all the way up. If it fell down, raise it with your hand and see if it stays up (there is a spring to overcome doing this). May be some crud keeping it from raising fully, torn rubber boot etc. Then just the right bump in the road could drop the lever and shut it down.
Old Mar 10, 2016 | 08:51 AM
patdaly's Avatar
Yep, it is either what Gorms said or a hold circuit issue, those are the only 2 real possibilities.
Old Mar 20, 2016 | 03:13 PM
Amos's Avatar
Thanks everybody! Found the old FSS was the problem. The boot was destroyed and when I took the old solenoid off the entire thing fell apart in my hands. The new one is on and the truck is back on the road.
Pearce
Nov 28, 2008 12:18 PM
diesel69
Jul 7, 2008 07:31 PM
smoky05
Jan 9, 2008 08:40 PM
idacal
Mar 13, 2007 02:12 AM
